Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Carburettors
Old 02-03-18, 10:00 PM   #1
Default Petter A? carb
Looking at a Petter A? and wondered if there is anything missing from the carb (apart from an air cleaner) as the machined surface with holes in looks like it should have something on it?
PetterV by Robert Starr, on Flickr
PetterC by Robert Starr, on Flickr
Old 02-03-18, 10:05 PM   #2
I think that certain iterations of this carb have an enrichening device fitted to that mounting point that is used for cold starting in place of a choke flap in the intake. I had a Petter PU2 fitted with a 26FH with just such an arrangement.
Old 02-03-18, 10:13 PM   #3
So the holes may be "as cast" and just not drilled/tapped in this application?
Old 02-03-18, 10:22 PM   #4
Yes. I had to replace the throttle housing part of my carb as it had a broken flange. I was lucky that I had a spare from a JAP 6 carb. That was a 26FV like the one fitted to your A and despite it being of a different set up I was able to use it on my engine by drilling out the necessary passages. ISTR that all the threads were already tapped which was a massive bonus!
Old 02-03-18, 10:25 PM   #5
Here you go mate, here's my little thread about it.
http://www.stationary-engine.net/for...ad.php?t=35703
Edit, I had to tap the threads........... My memory is slipping!
Old 02-03-18, 10:26 PM   #6
Not my engine, just one I'd seen advertised and the seller doesn't seem to know whether it's complete.
I'm not really sure even what model it is just guessed it's an A1?
Old 02-03-18, 10:40 PM   #7
That looks like an A1 to me. The A1 normally has a 24 T2 carb. My A has a 26FV but that one does not have the cold start device mounting.
Old 02-03-18, 11:13 PM   #8
Nothing "missing" just not fitted, be fine as it is....
Old 02-03-18, 11:14 PM   #9
And it's an A1, probably is the right carb, some had the Solex carb fitted
Old 02-03-18, 11:27 PM   #10
Thanks for the confirmation
