Old 01-01-18, 03:48 PM   #1
Default Conord F0 Engine
Well, my New Years goal of reducing the collection rather than growing it lasted a full 10 hours... This lovely little Conord popped up this morning locally, so I adopted it!
Does anyone have any information on these engines please? Are they the same as the Bernard W0? Does anyone have a spare fuel tank that is better than the lace curtain that I have please?
Thanks & Regards,
Happy New Year!
Old 01-01-18, 05:31 PM   #2
2010macjac
2010macjac's Avatar
10 hours! You have one well looks a interesting little lump. That tank has deffinaty seen better days! Could you not make a complete new bottom panel for it?
Old 01-01-18, 05:37 PM   #3
A new bottom panel will probably be the fix, however it will be a challenge as it has been subjected to weld, solder, glass fibre resin and epoxy in previous attempts to seal it by the looks of things. It's going to take a lot of cleaning to get back to a point where solder will stick reliably. It will go in the restoration queue whilst I keep an eye out for spares.
Old 01-01-18, 06:58 PM   #4
2010macjac
2010macjac's Avatar
Ah I see hence the wanted request. Well I've seen your workshop and your not lacking in projects! Put this under the bench and get on with that hornsby, I really want to see that running
Old 01-01-18, 08:14 PM   #5
oliver
oliver's Avatar
Hi Dan
that engine dates from 1938 and is a type 3 F0 made up till 1944 when the type 4 was produced and the only difference to a Bernard W0 is the conord name plate .bernards stopped production of conord engines when they acquired the company in 1929 . The fuel tank problem is a common problem with this type of engine due to water ingress through the top of the tank where the fuel tap spindle goes ,there are tanks about but they take some finding (it took me 2 years to find one ) ignition timing is measured using circumference of the fly wheel so 58mm before tdc inlet valve clearance 0.3mm exhaust 0.4mm
Old 01-01-18, 08:27 PM   #6
Originally Posted by oliver View Post
Hi Dan
Brilliant! Thanks Oliver for the information. I think the tank can be repaired (when I've nothing else to do!!!), though I will keep an eye open on eBay and at Nuenen for a better one.
Regards,
Old 01-01-18, 08:33 PM   #7
Tank on mine also has some old epoxy 'repairs' - holding for now!
Francoise Barral is your best bet for info and parts.
Old 01-01-18, 09:30 PM   #8
Nice buy Dan! Not sure if I spotted it in the same place as you but too far North for me.... would quite like one as they are cute wee things.
WW1 ABC, Norman SC, Sattley TA, Scott SE, Stuart H1, K, R3 & WD, Teagle B2, Villiers WX11
Old 01-01-18, 09:50 PM   #9
Probably. It popped up on Facebook, and seen as it was only 15 miles away I was there within an hour!
