Old 30-12-17, 08:02 PM   #1
Harty
Default 2 stroke ratios
Whatís the ratio I should use for the midget? Thereís so many conflicting views on the google.
Iím thinking 1:24. Whatís your view folks?
Harty is offline   Reply With Quote
Old 30-12-17, 08:18 PM   #2
With modern two-stroke oil and running light, I generally use 25:1 on plain bearing engines and 50:1 (or 24 and 48 depending on how you mix) on those with rolling element mains and big end.
Usual disclaimers if your engine seizes up solid after five minutes!
Old 30-12-17, 08:27 PM   #3
1956ld1
1956ld1's Avatar
With my midget, I use about 20.1 with a custom mix of oil, 50 parts 30sae motor oil with 50 parts mineral two stroke. Midgets where originally used with 16.1. When choosing oil choose mineral.
Old 30-12-17, 08:42 PM   #4
Harty
Brilliant thank you
Old 30-12-17, 10:34 PM   #5
Just check whether you are using mineral or synthetic as the ratio's are quite different, e.g. my brushcutter handbook specifies 25:1 mineral or 40:1 synthetic.
