Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Petrol Engine Section
Old 19-12-17, 02:04 AM   #1
basewindow
basewindow's Avatar
Default Ronaldson-Tippet N type
As I've just restored a Lister 3.5 CS and am just starting work on a Bamford SD1, my neighbour decided to drop up a Ronaldson-Tippett N type petrol engine which had been sitting in his shed for years and wasn't working.
I know virtually nothing about it but it looked fairly complete including water hopper.
I only had a brief go at it. Removed carby and fuel tank and dismantled and cleaned both. Dismantled and cleaned fuel suction pipe into tank.Released frozen governor linkages etc, new spark plug. It has spark on cranking. Compression is good.
Put it all back together. On cranking im getting a little smoke out the exhaust but also some blowback from around the carby area. Initial thoughts?
The timing probably needs looking at?
Haven't taken the head off or even looked at the magneto yet.
As I said i know virtually nothing about these engines.
Cam
basewindow is offline   Reply With Quote
Old 19-12-17, 02:21 AM   #2
If the smoke is blowing back through the carburettor then Your inlet valve isn't seating properly. If it's blowing back from around the carburettor area then it could be a dodgy "manifold" gasket or head gasket. How "good" is the compression? You'd be better stripping it all down if it's been stood for a long time, cleaning and checking all the parts for wear or breakage, rather than just trying to run it "blind", and risk causing damage.
Numquam illegitimo carborundum. 1918 Renfrew 1.5hp;C.1919 1.5hp Simplicity; undated 1.5hp Lauson Frost King. 1933 Quentin C1.Undated Nelson "Little Jumbo".
Old 19-12-17, 09:22 AM   #3
G'day Cam, from across the ditch. The R and T N is a very good engine. I restored one many years ago It would start with out a crank handle, just by pulling over the flywheel.
I have just finished restoring, but waiting for the magneto to come back from an overhaul, a NA [air cooled]
I think yours will need a valve grind. If it has an impulse mag the timing should be OK.
Good luck with it,
Merv.
Old 19-12-17, 09:45 AM   #4
basewindow
basewindow's Avatar
Thanks for the replies.
Looks like a strip down job then, which is ok by me, I'll learn something about this engine. Not so good for my neighbour who i think was hoping I'd get it going in a day or so.
Apparently he bought it years ago to fix up and never got started.
When i get time, I'll start on it and let you know how it goes.
It looks fairly simple, just from a cursory look, so fingers crossed.
Cam.
Old 19-12-17, 02:38 PM   #5
Combustor
Combustor's Avatar
Default Ronnie N type
Hello Cam,
If an engine is free, has spark, fuel and some compression then it is worth trying a start. Valves may just have some grit or carbon lodged under them. Take the sidecover off the tappet box (below/behind the tank) and with piston on compression stroke, lift the valve stems with a screwdriver etc, and allow them to snap shut a few times. Then see if you have restored compression enough for a start. No point in looking for head gaskets and valve grinding gear if it's not needed. Enjoy the project. Good little motor you have there. Regards,
Combustor.
Old 01-01-18, 11:41 AM   #6
basewindow
basewindow's Avatar
Decided to take the head off and have a good look.
Filthy of course. Gave it all a good clean. Valves were dirty but operating, but gave them a good clean up. Gave head a good clean up.
Totally stripped and cleaned carby. Removed a cleaned governor linkages and checked governor etc. Cylinder looked ok.
Plate says this is a Gippsland and Northern co-operative 3hp at 1000rpm.
Assuming this is a rebadged Ronaldson-Tippett N type.
Will give it a paint and put it all back together and see how it goes....
Old 03-01-18, 03:29 AM   #7
basewindow
basewindow's Avatar
Put it all back together. Got it to fire for about 4 to 5 compressions then stops. Definitely getting blow back out through the carby so I'm guessing it's the inlet valve not seating correctly. Will take it apart again over the next few days and see if I can do any adjustments otherwise I guess it's a grind.
Cam.
Old 03-01-18, 02:29 PM   #8
Combustor
Combustor's Avatar
Default Ronnie N series
Hello Basewindow,
Should be able to check tappet clearance with a feeler gauge with the sideplate removed, and as long as it has a few thou clear, it should run. If still leaking then guess you need to look at grinding and/or refacing valves, good luck,
Combustor.
Old 18-03-18, 12:32 PM   #9
basewindow
basewindow's Avatar
Finally had a chance to look at the Ronnie again. Went over it all again. Valves seated well, opening and closing correctly, adjusted value clearances. Carby cleaned checked and adjusted. Governor linkages all operating smoothly, governor weights checked all free and lubed. New homemade gaskets and seal etc. Spark plug cleaned and gapped. Good spark. What else?
Only thing i hadnt checked was the magnito. Why? Well it had spark, i didnt want to fiddle with something that was probably working and i didnt know much about. My neighbour said he'd had it in the shop a few years back and had new leads and spark plug fitted. Surely the bloke at the shop had put it back together correctly?
Well it was the last thing on the list so what the hell, off and apart it came. After a brief inspection all became somewhat clear on how it functioned and what was probably wrong. From what i could tell the contact spark point was about 180 degrees out, so i was getting spark at completely the wrong time. Guess that could explain the blow back out the carby? Adjusted it to what i thought was correct lining it up with the spark line on the flywheel and groove on the casing and put it back together.
A few spins with the crank and would you know it, she fires up. Running roughly and needs some adjustments but running.
1953 CS Lister 3.5hp, 1938 Bamford SD1 3.5hp, 1951 Ronaldson-Tippett 3hp N type, 1962 Fordson Super Dexta, 1969 International 434.
Old 18-03-18, 06:03 PM   #10
Glad to hear you found the problem and it running now
Robotstar5 is online now   Reply With Quote
