Old 30-11-17, 07:25 PM   #1
antiBRIGGSANDSTRATTON
Default Lathe Spindle Nose Threads?
I have a Boxford CUD lathe here, with a 1.5'' x 8 TPI and have a number of chucks here that are a very similar thread, and screw on but they are a rather sloppy fit on there, one of these is a 'TRUGRIP' collet chuck, is there another spindle nose thread that is that similar?
Matt H
1947 D & F pumpset, 1943 close couple Lister Pumpset, 1931 & 1929 D types, 1929 Bruston D, 1930 Crossley 1030, 1942 Fowler PA, 1943 Fairbanks ZD, 1945 WD2, 1946 Bamford EG1, 1930 Superbloc 3hp, 1934 Conord F2, 1942 Ruston PT + driven equipment
Old 30-11-17, 07:58 PM   #2
Depends just how sloppy Matt? I have an AUD, and the backplates screw on with a bit of free play, until the nose register, behind the nose thread, engages with the matching socket in the backplate - then everything trues up nicely.
Old 30-11-17, 08:18 PM   #3
I have a 4 jaw and 3 jaw that fit really nicely, but these ones are much sloppier, but a couple don't screw down against the register, which makes me think they are a different thread, but I have used most of them to get me out of trouble before
Matt H
Old 30-11-17, 08:19 PM   #4
I would like to find out what they are so I can flog them on
Matt H
Old 30-11-17, 08:48 PM   #5
...or just replace the backplates with new ones. Easily available, except for 6", which have become a bit thin on the ground.
Old 01-12-17, 09:29 AM   #6
Ive got all the chucks etc I need for that lathe, so was looking to get rid of all the surplus chucks I have, I haven't used that lathe for a long time anyway, it wont get a look in when the Triumph gets plumbed in down the foundry
Matt H
Old 02-12-17, 08:08 AM   #7
stevelew
I have a Logan lathe that the Boxford was based on, so they share similar parts( so I have read) the main difference unless yours is a very early one is the nose thread on the Logan is UNC could you have UNC back plates?
stevelew is offline   Reply With Quote
Old 02-12-17, 11:55 AM   #8
Ah! possibly, UNC thread angle is 60 degrees which would explain why its got that bit more play than the others
Matt H
Old 02-12-17, 02:34 PM   #9
Originally Posted by stevelew View Post
I have a Logan lathe that the Boxford was based on...
I believe the Boxford was based on the American South Bend, which was a direct competitor for the Logan - I can't find any reference to the Logan being the inspiration for Denford/Boxford?
Old 02-12-17, 05:55 PM   #10
Hi Martin, I also thought there was some connection between South Bend and Boxford
Matt H
