Old 29-11-17, 08:31 AM   #1
gaudin98
Default Unusual CS diesel.
Came across this on youtube the other day. A new use for lister type of CS engine. Note the unusual use of an additional oil pump.
https://www.youtube.com/watch?v=dL50Nzi7bsI
Old 29-11-17, 05:34 PM   #2
Quite an improvement I'd say...
Old 29-11-17, 05:47 PM   #3
sidecrank
Three hundred years behind us.
sidecrank is offline   Reply With Quote
Old 29-11-17, 05:56 PM   #4
Or ahead considering it will run on anything which burns rather than just refined fuels! 25hp though - must give the bottom end something to think about.
Old 29-11-17, 08:26 PM   #5
Nice piece of work, especially given they have considered water carryover protection, but that in itself reveals something, they are using low temp, unsuperheated steam, so I'm very sceptical that it is producing even a nominal 25hp, 2.5hp would be closer to the mark.
Old 30-11-17, 09:25 AM   #6
adgecutler
adgecutler's Avatar
Standing on the shoulders of Giants.
I know nothing except the fact of my ignorance.
Jamie.
adgecutler is offline   Reply With Quote
Old 30-11-17, 10:40 AM   #7
ListerHA2
ListerHA2's Avatar
Appears to be using a 'Yarrow' type boiler.
https://en.wikipedia.org/wiki/Yarrow_boiler
Old 30-11-17, 10:56 AM   #8
I'm no expert in hot fog things, but the thermal losses must be huge with all that unlagged pipework, and as Paul says, 25hp is a bit fairy-tale.
It uses what was possibly a redundant engine, and wood is cheaper than diesel fuel, but horribly inefficient all the same.
Old 30-11-17, 11:46 AM   #9
(snip) 25hp is a bit fairy-tale.
Probably true - I sort of assumed they had at least done a basic 'P.L.A.N' calculation.
Old 30-11-17, 12:05 PM   #10
I think it was more for the camera than a practical setup.
