Old 27-11-17, 09:14 PM   #11
Noah Hemlock
Noah Hemlock's Avatar
Thank you very much indeed and have fun with the little one.
Thanks - Noah
Noah Hemlock is offline   Reply With Quote
Old 27-11-17, 11:18 PM   #12
Originally Posted by Paul_Sterling View Post
looking after the small boy, and welding the landrover.
So while you weld the boy can sit inside on fire watch/control
I have to say I spent many, many hours inside various cars armed with a kettle of water while the underside was welded.
Old 01-12-17, 03:05 PM   #13
Noah Hemlock
Hi again so for the spark plug would this be suitable ?
https://www.stationaryengineparts.co...park-Plug.html
Thanks - Noah
Old 01-12-17, 04:17 PM   #14
http://www.gsparkplug.com/1x-champio....html?___SID=U
Better choice
There are quite a few around that size to be fair. Be certain though that your engine has a 14mm head and not the 18mm head.
Something like this one if 18mm
Old 01-12-17, 04:19 PM   #15
Noah Hemlock
ok thanks much appreciated
Thanks - Noah
Old 01-12-17, 07:14 PM   #16
Originally Posted by Noah Hemlock View Post
Here is the fuel tank, I don't know if this is useful?
I'd say that was an A1 tank and not an A tank as the A tanks normally doesn't have a seam in the middle and has a brass screw cap rather than a 1/4 turn Ali one...
Also the A has its brackets welded on....
Old 01-12-17, 09:40 PM   #17
I have a starting handle for a Petter A and a tank cap to fit your existing tank.
However, as Paul has offered first, you should talk to him first.
Old 01-12-17, 11:29 PM   #18
Noah could be waiting a while if I have to find it Phillip, so please by all means if you have one ready and waiting, discuss.
thanks, Paul.
Old 02-12-17, 04:52 PM   #19
Noah Hemlock
Hi Phillip I tried to send you a pm but I don't know if it was successful
Thanks - Noah
Old 02-12-17, 05:55 PM   #20
NGK. B7HS is probably a better bet. Even though they sometimes have a long reach thread they run better with a short reach plug.
If it is an A and not an A1 then it'll be a 18mm plug I expect anyway so a D21 will be good.
