Old 23-11-17, 11:22 AM   #1
raggy 1
raggy 1's Avatar
Default Wolseley WD2 spitting oil from breather
My WD2 has always been a clean engine until recently.On its last run I noticed some oil had started appearing on the carburettor from the metal baffle plate. Its never done this before, the oil level is correct.It doesn't burn any oil and the compression is good.Is it new piston ring time??. Thanks
raggy 1 is offline   Reply With Quote
Old 23-11-17, 11:58 AM   #2
Is the filter in the breather clear Alan?
Old 23-11-17, 08:11 PM   #3
My WD8 has always done this if I run it without sufficient load, get it hot and well loaded it's fine.
Old 23-11-17, 08:33 PM   #4
Sounds like he bore is glazing up from running light, get a load on it and see how it goes (As Neil said)
Old 23-11-17, 08:51 PM   #5
The average Lister D or Wolseley is rated at 1.5hp, running a lister domestic type pump doesn't really constitute a proper load.
Never owned an electric driven domestic but i'd bet the motor is probably around 1/2hp
My Wolseley will run one all day, but will spit a little oil, add another load and the oil clears up.
Runs best when on a slow boil, which needs a lot more than a domestic pump.
Old 23-11-17, 09:00 PM   #6
The domestic and for that any piston pump really is no load at all because it has no head to push against, restricting the flow does something to help with this but even that is marginal.
Gear or centrifugal pumps seem to be the best way of using a pump as a load.
If you look at the specs for a domestic you will see at full load they actually used an L to drive, bet that looked odd....
Old 24-11-17, 12:32 AM   #7
I just happen to have one here's the data plate...
MotorDataS by Robert Starr, on Flickr
Old 24-11-17, 12:56 AM   #8
I very nearly said 1/4hp, but had a look at the modern makers website, that gives 1/2hp or optional 1 hp.
The way they are generally run they give, as Rob says next to no load.
I do tend to put a restrictor on the outlet of any pump I run, it gives the pump at least something to push against.
Old 24-11-17, 01:10 AM   #9
Even pushing all those Yellow ducks round?
Old 24-11-17, 05:11 PM   #10
raggy 1
raggy 1's Avatar
Yes Pete,it was a new one not long ago,it started the oil thing just before I fitted it.
