Old 28-11-17, 10:22 AM   #31
Thanks, confirms that mine has been rewired internally.
Old 29-11-17, 09:43 PM   #32
Harddisk25
Harddisk25's Avatar
Evening all, Just a quick update. I've managed to get the marvil sparking tonight, all being well tomorrow I'm hoping to get her running again.
Harddisk25 is offline   Reply With Quote
Old 01-12-17, 11:26 AM   #33
Harddisk25
Harddisk25's Avatar
Morning all, Tried to get the Marvil started today. Got a couple of pops but that's it.
Any ideas?
Thanks Chris
Old 16-12-17, 11:47 AM   #34
Andrew46
Harddisk25
Did you manage to get your mar-vil going in the end.
Andrew46 is offline   Reply With Quote
Old 17-12-17, 07:03 PM   #35
Harddisk25
Harddisk25's Avatar
Originally Posted by Andrew46 View Post
Harddisk25
Hi, Andrew. I had it running for a couple of seconds after a new condenser but that's it. I've also put it new points and awaiting on a new coil. Shes sparking ok but not strong enough to start again.
Old 19-12-17, 02:29 PM   #36
Harddisk25
Harddisk25's Avatar
I've got the Mar-Vil running at long last, Just wanted a new mag setup. Here's a video of it running: https://youtu.be/Y53KWyLDivw
Old 19-12-17, 04:05 PM   #37
woodsman
Well done - dead jealous
Regards Paul
Old 19-12-17, 06:02 PM   #38
Looks and sounds good does the generator work or is it next on the list?.
Old 19-12-17, 09:40 PM   #39
Harddisk25
Harddisk25's Avatar
Hi Stuart, Thanks for the comment. The generator is next on the list as it needs a replacement 2" pulley and v-belt. Also got to sort out a kill switch for it.
Old 19-12-17, 10:19 PM   #40
Does it not haver a fuel shutoff below the carb ?
