Old 22-11-17, 12:46 PM   #21
Harddisk25
Harddisk25's Avatar
Well I've got it off, Just remembered i had a homemade hammertight spanner in the tool draw. Couple of blows and it was off.
Thanks
Harddisk25 is offline   Reply With Quote
Old 22-11-17, 01:02 PM   #22
Well done.
Was going to warn that the spanners do come in different sizes, for instance the one I have doesn't actually fit Mar-Vil but as I said, never has one stick too badly - normal ring spanner and rubber mallet usually does the job.
Last edited by nickh; 22-11-17 at 01:05 PM. Reason: in different - not indifferent!
Old 22-11-17, 02:58 PM   #23
'Don't force it, just get a bigger hammer'
Old 23-11-17, 04:59 PM   #24
Harddisk25
Harddisk25's Avatar
Afternoon all, I've gotten to the stage now were i'm adding the flywheel back on. With the Mar.Vil how do you set up the timing?
Thanks
Old 23-11-17, 06:09 PM   #25
Can't find my instruction leaflet at the moment (available from IF) but if I remember correctly it's simply set piston to TDC and line up marks on flywheel mag.
Old 23-11-17, 07:40 PM   #26
Harddisk25
Harddisk25's Avatar
Thanks for the settings.
Old 24-11-17, 05:18 PM   #27
By the way, I have a Dextor dynamo in rather 'got at' condition and I have to thank you for the pics you are adding which should help me get it back as it should be.
Old 24-11-17, 05:28 PM   #28
donp
I would like to say thank you as well to this forum member Nick, the photos of the Vacturi carb. are welcomed by me.
donp is offline   Reply With Quote
Old 24-11-17, 07:24 PM   #29
Harddisk25
Harddisk25's Avatar
Your welcome nickh & donp, I like to document most of my projects for future reference.
If anyone wants to share my pics to help others your welcome to do so.
Old 28-11-17, 02:01 AM   #30
Harddisk25
Harddisk25's Avatar
Just got round to drawing the wiring diagram for the Dexter. I don't know if would help as yours has been rewired but here it is.
