Old 20-11-17, 02:15 PM   #11
My book is No 68/152 with no amendments attached.
Yes, my second reference should have read "68/152". Sorry, a slip in my note-taking.
Old 20-11-17, 02:22 PM   #12
My 68/152 doesn't cover the F or FK only the D and DK
Old 20-11-17, 05:09 PM   #13
As I said in my posting, It's 68/341 that covers the D,DK,F & FK. Yours's just covers the D & DK. I just got the number wrong, as I explained.
Old 20-11-17, 05:59 PM   #14
It was the Late David Edgington who admitted to me during a phone call that 31 thou written in his books was wrong, a misprint apparently, though possibly now correct? He referred me to David Harris (ex Lister field engineer for those not knowing of him) who told me that he didn't bother measuring the gap when overhauling an engine as they are a little fiddly to access with feeler guages but as long as there was some movement that was good enough for an engine running at D Type speeds. I mentioned "Around 10 thou then?" and he said it would be fine so that's what I use. Up to the individual I guess, my first D's were set to 31 thou and were a little 'clattery' but ran just as well as the later ones with a smaller gap! I remember something Ray Hooley told me once in an email after I requested some Ruston information; "You lads worry more about your engines than we ever did while making them" and he is probably correct!
Old 20-11-17, 08:21 PM   #15
gamefarmone
Default Lister Valve Clearance
Agree with you completely, Pete.
I've rebuilt many an engine, many without specs being available, but they all seemed to run just fine without technical "correctness" being used- as long as the basics were followed.
I've just never rebuilt a Lister, so the specs in the manual I found seemed quite tight for valves.
The "misprint" title on the attachment I posted is mine-just so I don't forget the discrepancy sometime in the future...memory not being what it used to be.
I'll probably open up the clearance quite a bit- maybe 0.10 + cold on the intake, and 0.20+ cold on the exhaust to allow for more heat expansion.
The engine actually ran fine on the .003 lashing, but I didn't let it get hot.
My mechanical style is pretty much summed up by the reply of the elderly mechanic when asked what ft.lbs he used to torque an old engine head down.
"I pretty much like to torque it down to just before the bolt breaks"
Thanks to all for the input.
Tmann
gamefarmone is offline   Reply With Quote
Old 26-12-17, 02:50 PM   #16
loveboat
Note that the (revised) manual says clearance should be .003" when hot. Note the 'hot' word. This therefore is probably not too tight a clearance at all but just right when the engine is running.
I myself have never checked the clearance when hot as, following the advice on this forum somewhere or other, set them both to 5-10 thou when cold. As the tappets still have clearance when the engine is hot, this seems reasonable.
There are a number of videos on Youtube where the owner removes the tappet cover from his beloved while it is running and you can hear a loud clunking noise come out. One can guess that in these cases the tappets have been faithfully adjusted to .031".
loveboat is offline   Reply With Quote
Old 26-02-18, 02:40 AM   #17
loveboat
The book "Overhauling Lister D & DK type engines - Technical specification and Data Booklet" written by David Edgington states the following:
Tappet Clearances (cold) both Inlet and exhaust .005 to .010 ins.
Having become curious about this issue I wheeled out my loved one for some tests. I first made some fancy feeler gauges by bending them in half and gluing one side to a strip of steel. This made getting the gauge into the tappet space very easy.
I first tried setting the tappets to .003" while they were hot. This was very difficult and the tappets had a tendency to still reduce their clearance the next time the engine was run. I therefore abandoned any attempt to set them while hot and would not recommend this to anybody.
I then run a series of tests (about 20) setting the tappets while cold and measuring them again while hot. The contraction in the clearance varied from .000" to .002", with the inlet valve showing the most variation. If set to .003" while cold the tappet clearance for both valves would always contract to about .001".
From this experience I would suggest that setting the tappet clearance to .005" to .007" would be ideal but obviously all engines are different and your mileage may vary. After setting the clearance while cold the setting should also be checked again while hot to ensure the clearance is still greater than .003". If the tappet screw is 'mushy' the tappet might need setting once or twice more to ensure it settles down at the correct clearance.
