Old 20-11-17, 12:16 AM   #1
gamefarmone
Default Lister D valve clearance
I've been reading several articles, trying to locate the proper valve clearance for my Lister D. The numbers I've seen seem to be all over the map.
I eventually found a downloadable version of the actual manual, in which it lists .003 (hot) as the clearance for both intake and exhaust valves.
( My valves seemed a bit loose, and the engine seemed to not be running as it should, with a marked problem starting)
This seems to be very little clearance, so just wondering if it may be a misprint, or is this the actual clearance?
Thanks for any input from experienced Lister rebuilders.
Tmann
gamefarmone is offline   Reply With Quote
Old 20-11-17, 12:37 AM   #2
My operators manual states .031" cold for inlet & exhaust.
Old 20-11-17, 01:30 AM   #3
gamefarmone
Stuart, thanks for the reply.
I went back and looked at my print, and sure enough it does say .003"
Guess putting the decimal point in the wrong spot makes worlds of difference, huh?
Your # sounds much more reasonable.
Thanks for the reply.
Tmann
Old 20-11-17, 10:38 AM   #4
The 31 thou is a well known missprint actually! The author admitted that he got it wrong, .003" seems a little tight to me but I set mine to .010" and have never had any problem.:righton
Old 20-11-17, 10:50 AM   #5
Just had a look at the Lister D restoration book and that has the wrong value in too, must have quoted from the same source?.
I've stuck "post it" notes in both as a reminder of the correct clearance
Old 20-11-17, 11:22 AM   #6
Maybe time to look at updating some of our own forum notes and doc's?
I put a section in some years ago but it doesn't get used much.
Old 20-11-17, 11:31 AM   #7
Gentlemen,
We have a small quandary to consider, I recently bought an original Lister D petrol and Petrol-Paraffin instruction book and new crankshaft off of a ex Lister engineer and it states on page 2 the valve clearance when cold should be set at.031".
Old 20-11-17, 12:04 PM   #8
The page reference that "tmann" showed is from Booklet 68/341 (covering the D,DK,F & FK) which clearly states .003" but when You click on his attachment it says "Lister manual misprint.jpeg". Booklet 68/152 (covering the D & DK) clearly states .031" cold. From memory I think I've always set mine to around 10>12 thou, as Pete recommends.
Old 20-11-17, 12:16 PM   #9
My book is No 68/152 with no amendments attached.
Old 20-11-17, 12:19 PM   #10
I have no idea what is correct for the "D", but 31 thou is 1/32", which is the clearance Lister used on a lot of the other petrol engines, so I can see how the mistake(?) may have slipped in...
