Old 08-11-17, 09:51 PM   #1
EarlBathurst
EarlBathurst's Avatar
Default Metal Stitching
Hi all,
Can anybody Recommend somebody that can do on site metal stitching Please?? I have a rather large cylinder under my control that has some cracks around a couple of studs.
Thanks,
Karl.
Old 08-11-17, 10:20 PM   #2
https://www.metalock.co.uk/
Old 08-11-17, 10:30 PM   #3
EarlBathurst
Thanks Martin.
I will be ringing them in the Morning.
Karl.
Old 08-11-17, 11:06 PM   #4
I remember Metalock repairing a big rolling machine at the factory where I was an apprentice over 50 years ago. They did an excellent job of "cross-stitching".
Old 09-11-17, 08:02 AM   #5
EarlBathurst
This is for a steam a four cylinder steam loco. Its sister had the same problem a few years ago that was stiched successfully .
Old 09-11-17, 08:35 AM   #6
CSdiesel
Cox & Turner advertise metal stitching but never seen their work Karl !
Thanks
Janner
Old 09-11-17, 09:11 AM   #7
sinna42
sinna42's Avatar
I used this chap : Surelock - http://www.castingrepairs.com/
See the 3M thread - post #36.
http://www.stationary-engine.net/for...t=31297&page=4
Jim
Old 09-11-17, 02:44 PM   #8
NELPG had the J27 done some time back, but it did ultimately fail again, and they are on to a replacement cylinder block now.
Not to say that stitching does work on steam locomotives, just that in that case, the frame stretcher nature of inside cylinders puts a lot of extra load in there.
Old 09-11-17, 06:36 PM   #9
Bulldog engines
I couldn't agree more with Martin as far as metalock services are concerned, I've had an aermotor engine stitched back together after the main casting got split, it has lived to tell the tale.
Bulldog engines is offline   Reply With Quote
Old 09-11-17, 07:54 PM   #10
EarlBathurst
Yes i remember that ! this is a outside right hand cylinder. the sister loco had the same problem a few years ago and Matalock stitched that for them. They are Like the J27 having new cylinders fitted. We are having an NDT inspection done then Metalock will hopefully carry out the necessary work.
Karl.
