Old 03-11-17, 05:19 PM   #21
Can't quite make out the supplier. Here's a better picture of mine.
C360_2015-12-14-14-00-18-923 by Stephen Williams, on Flickr
Old 03-11-17, 05:43 PM   #22
Mister_D_Lister
Mister_D_Lister's Avatar
Thanks Steve - confirms where the wandering wire should be anyway. Do you have any info on the coil & condenser at all?
The HT lead has been cropped right back & will need replacing, anybody got any hints on soldering a new one onto the coil contact please?
1934 Stuart Turner R3
1953 BSA 300W charging set
Mister_D_Lister is offline   Reply With Quote
Old 03-11-17, 05:59 PM   #23
Somewhere on here is a potted history of WICO / WIPAC in the UK. I think the first sales office was Acton, then Perivale (also factory), then Bletchley and finally Buckingham.
Old 03-11-17, 06:02 PM   #24
Didn't they have a factory in Southam at some time.
Old 03-11-17, 06:41 PM   #25
Sadly not, I've been unable to find a suitable coil, I was wondering if a WICO X coil would fit, I've not taken mine any further apart. I will probably send it off for rewinding when I get the time.
Old 03-11-17, 06:48 PM   #26
Do you reckon mine (1941 I think) will be WICO or Miller Steve? Latter is probably just as likely to be kaput anyway.
Old 03-11-17, 06:53 PM   #27
From the looks of the back plate I would say it was a Miller, they had a fairly small flat back plate IIRC. Villiers Parts have coils for the Miller units, I think the back plates are known to be a bit fragile as well.
Old 03-11-17, 06:56 PM   #28
Originally Posted by skankin_giant View Post
(snip) Villiers Parts have coils for the Miller units
That's worth knowing, thanks.
Old 03-11-17, 08:43 PM   #29
Mister_D_Lister
Looking at removing the head, barrel & expansion chamber, the gaskets look like they have seen some life. Seen fibre ones on Ebay for 25 a set or with a copper head gasket for 30 a set. Does this sound like a good deal?
Old 03-11-17, 08:52 PM   #30
I find it better to just make my own as and when I need them, paper is cheap, around .90p an A4 sheet.
Head gaskets are all I would buy, if they are available.
That said if the head to barrel joint is the same as my P5 in design a heavy paper gasket would probably work ok
