Old 01-11-17, 10:00 PM   #1
Anton
Anton's Avatar
Default Taps & dies
Please help!
what is the difference when I have a tap imprint 1/2 BSP 14TPI and a tap G 1/2" 14 TPI and a tap R 1/2 14 TPI???
Anton
Anton is offline   Reply With Quote
Old 01-11-17, 10:08 PM   #2
Anton,
Look at this link https://www.festo.com/wiki/en/Threads_in_pneumatics
Old 01-11-17, 10:30 PM   #3
Anton
Anton's Avatar
Default taps & dies
Anton,
thanks for quick reply Martin, but maybe I must ask: can I use a G1/2" tap instead of a 1/2"BSP tap?
Anton
Old 01-11-17, 11:04 PM   #4
cccst70
Anton
1/2" G is the same as 1/2" BSPT which is the taper version.
make sure you don't run a taper thread all way thru a parallel as it will over cut on top of taper tap
NPT is slightly different thread angle I think also pitch is slightly different
cccst70 is offline   Reply With Quote
Old 01-11-17, 11:22 PM   #5
BSP is 55 degree angle, NPT is 60
Some sizes swap around easily, some (like " BSP) will but it is really tight.
Although it will work at normal pressures, like water pumps etc, high pressure compressors (200psi +) and certainly hydraulics it will cause leaks.
Old 01-11-17, 11:30 PM   #6
(snip) 1/2" G is the same as 1/2" BSPT which is the taper version.
I presume the G = 'Gas' then but what is the 1/2" R?
Old 02-11-17, 01:19 AM   #7
ListerHA2
ListerHA2's Avatar
https://www.festo.com/wiki/en/Thread...or_R-thread.3F
"G-thread or R-thread?
G-threads have a cylindrical form in accordance with EN-ISO 228-1. R-threads have a conical form in accordance with EN 10226
In the case of a thread size 1/8", for example, the threads are specified as G1/8 or R1/8.
The following rules must be adhered to when using a combination of G and R-threads: Male G-threads (cylindrical) can only be screwed into female G-threads. Male R-threads (conical) can be screwed into female G or R-threads."
Old 02-11-17, 10:07 AM   #8
Ah; R = 'Running' then.
EDIT; Sorry, t'other way round so I am none the wiser as to the origin of the G & R designations, probably looking for a logical 'reason' when there is none!
Thanks.
Old 02-11-17, 02:14 PM   #9
Anton
Anton's Avatar
Default taps & dies
thanks guys for all the information!
Anton
Old 02-11-17, 03:36 PM   #10
AdeV
Thanks.
According to Wikipedia, they're from German: G for "gas" (as it was originally used on gas pipes, and "R" for "Rohr" = pipe). Which makes it about as clear as mud!
AdeV is offline   Reply With Quote
