Old 02-11-17, 09:51 AM   #11
Originally Posted by philipagri View Post
Is that with a spoked flywheel as well, or am I just seeing things as it looks large diameter?
I did wonder if the later spec11's had the second style tank or not.
Yes, the Winget 18" spoked flywheel for slow running/low HP applications. Actually a lightened A type flywheel with no balance weights. Supplied to Winget on 20/4/29.
Old 02-11-17, 02:08 PM   #12
Here's my old Spec 11DRS Serial No:- 93666. (Supplied to Winget's in March 1930) with the low tank and no float chamber.
Old 03-11-17, 09:01 AM   #13
williams8781
williams8781's Avatar
Will measure the tank and rad for you today Phillip. I should contact Doreen about the engine and others. I have a feeling that the engine and pump was a hire company's and i suspect that somehow something was dropped onto in knackering the head and tank. Just a theory....... so to make the changes it could be quite costly ?
Thanks
Most run.....
williams8781 is offline   Reply With Quote
