Old 22-10-17, 06:30 PM   #1
1956ld1
1956ld1's Avatar
Default AVO Model 7 question
Hi all,
Ive had my model 7 for a while now and I love using it. Ive read the back a few times and ive noticed the meter is capable of reading capacity. It does give instructions but im confused. Is it as simple as putting a capacitor in series with the mains and hooking it in to the normal terminals? If so, is there a way of getting it to measure over 20uf of capacity?
Any information is much apreciated on the meter as I would love to use it more.
Regards,
Josh.
Old 22-10-17, 06:56 PM   #2
I acquired a new never used Avo in its box a couple of years ago, I will dig out tomorrow and see what I can find.
Old 22-10-17, 07:15 PM   #3
Nice things, Iíve got a model 46a and a 7. Is the battery still good in your meter?
Old 22-10-17, 07:23 PM   #4
I bought new battery's for my meter.
Old 22-10-17, 07:34 PM   #5
Where from if you donít mind my asking? Both of mine need them.
Old 22-10-17, 07:42 PM   #6
To be honest cant remember but will look tomorrow at batteries spec no's
Old 22-10-17, 07:48 PM   #7
The special battery for the high ohms ranges was unavailable for a while, but they are available again from trade suppliers and sellers on ebay.
https://www.ebay.co.uk/sch/i.html?_f...ttery&_sacat=0
Old 22-10-17, 08:58 PM   #8
Thanks Peter
Old 22-10-17, 09:56 PM   #9
1956ld1
1956ld1's Avatar
my meter is designed for 2 4.5 volt cells in series for 9 volt so I replaced them with a standard 9v battery conecter which works wells and I use a standard d type cell with wires soldered on for the low voltage. ive had them batteries in it since I got it and havnt had to change them. As for the model 8 batteries (15v) I heard that stacking penny batteries will work. Unfortunatly my meter didnt come with a case but by the looks of it, the movement is new since there is no hand written date at the bottom. Does anyone know hoe to date these model 7s?
Old 22-10-17, 09:57 PM   #10
1956ld1
1956ld1's Avatar
I beleave it was only the model 8s and higher that required the 15v cell so u should be fine with a 9v battery instead
