Old 26-10-17, 05:38 PM   #21
<snip> Stuart, I'm not knocking the military, when I retired work had three, two ex army and one ex RAF, the only issue I had was their desire to take charge of everything even when they didn't have a clue what they were doing.
Apologies if that was the impression I gave, it's difficult from a keyboard
They do sometimes get frustrated at the "civvy" approach some jobs.
Old 26-10-17, 05:49 PM   #22
(snip) the only issue I had was their desire to take charge of everything
Including forums?
My little box of tricks which seems to work ok but I seem to remember was a tad 'challenging' to program.
Old 26-10-17, 05:53 PM   #23
Including forums?
They do seem to have lots of parameters to "play" with but probably only a handful of important ones.
Old 26-10-17, 06:24 PM   #24
Needed to configure it to recognise remote stop / start buttons, toggle reversing switch plus a slow start / rapid stop function.
Old 26-10-17, 06:47 PM   #25
Need to get my finger out and find the correct 3 ph motor for my lathe to get mine up and running.
Old 26-10-17, 06:49 PM   #26
antiBRIGGSANDSTRATTON
I got given a Colchester Triumph 2000 the other day, was looking into trying to find an inverter for it but its going to live at work now where there is 3 phase so that's not a problem now, few inverters on ebay
Matt H
1947 D & F pumpset, 1943 close couple Lister Pumpset, 1931 & 1929 D types, 1929 Bruston D, 1930 Crossley 1030, 1942 Fowler PA, 1943 Fairbanks ZD, 1945 WD2, 1946 Bamford EG1, 1930 Superbloc 3hp, 1934 Conord F2, 1942 Ruston PT + driven equipment
Old 26-10-17, 06:58 PM   #27
Harrington you git!
A short gap-bed Triumph is on my "to do" list, although quite frankly if I ever find the money for that I'm much more likely to buy an engine!
Old 26-10-17, 06:59 PM   #28
Must say the machine does run much nicer than with the single phase motor (feels like it has more grunt) and of course the variable speed is a boon.
Old 26-10-17, 06:59 PM   #29
Matt,
Your best bet is to contact one of the companies listed in this link.
Old 27-10-17, 02:43 PM   #30
JohnD
JohnD's Avatar
I too can vouch for drives direct, I've a teco from them powering my student 1800.
Great service,and easily reached by phone should you need help
I wanted to use the existing controls on the lathe,which was easily done and I mounted the VFD in an enclosure under the lathe itself.
It works well,the only thing I'm missing is a external pot which I'll add to the lathe at some stage.
Once I get my hands on a mill it'll be adapted to run the mill from same VFD.
Best of luck with the new lathe!
JohnD is offline   Reply With Quote
