Old 26-10-17, 11:56 AM   #11
Chippie
Jim,
I have a vfd on each of my three machines, 2 lathes and a mill.
The smaller lathe has a Teco vfd, the existing stop/ start and fwd/rev are utiised with the inverter.
My bigger lathe and mill each use an Invertek vfd bought from Engineers Mate ( google) Both are rated at 1.5 kw and run from a std 13A socket.
For speed range, I wouldnt have it any other way, vfd and 3 ph motor gives great flexibilty....and the cost isnt prohibitive.....
Old 26-10-17, 01:10 PM   #12
Anton
Anton's Avatar
Default new lathe
https://elektromotor-online.nl/produ...-ip20/?lang=en
have a look at elektromotor-online
Anton
Anton is offline   Reply With Quote
Old 26-10-17, 01:41 PM   #13
sinna42
sinna42's Avatar
Thanks !
It does look like the consensus is to abandon the original machine controls and use these inverter drives with a pendant control for fwd/stop/rev & speed.
The prices are really not that much.
Jim
Old 26-10-17, 01:55 PM   #14
Chippie
I have the Teco L510 unit fitted to my smaller lathe, very good it is....but my advice fwiw, avoid the E2 series.....the power supplies inside are prone to going pop! They are old models anyway....( I know from past experience of having repaired many of them that I got from Dave at Drives Direct)
Old 26-10-17, 03:58 PM   #15
Jim
This is what I'm using to run a 2hp Tom Senior Major. It came from "Drives Direct" in Nottingham, and I can't recommend them enough - very knowledgeable and helpful.
Yes, it needs to be wired directly to the motor, but by using the optional wired remote control you get a control panel (including speed control) that you can position anywhere.
I completely removed the motor controls from the TS, and glued neodymium magnets to the back of the remote, so that I can park it wherever it suits me on the machine.
The inverter does lots of useful things, including ramped start and stop, and even has an automatic programme to "tune" the motor for best results.
Another vote for drives direct, they have good feedback on another forum I'm on. I didn't know Yaskawa did drives as well, I've programmed a few of their robots in the 80's.
Cable entries could do with a bit of strain relief
Old 26-10-17, 04:09 PM   #16
Stuart,
Martin is ex RAF, that's obviously how he was taught to do it
Old 26-10-17, 04:18 PM   #17
Taught? Who says I was ever taught anything?!
Yes, they could do with strain relief, but the units are designed for cabinet mounting and don't have the facility. The plan was to sort something out once it had worked successfully, but since it's working successfully I've more important things to be doing!
Old 26-10-17, 04:28 PM   #18
Stuart,
Can't knock ex forces, JLR employ quite a few ex-service folks, we have an RAF guy as a Sparky and a REME guy as a fitter in the maintenance dept. on our area and they both show an amazing attention to detail when working
Old 26-10-17, 04:32 PM   #19
VFD's normally have a cable support bar under the terminal bank with metal clamps to bear down on the cable screens.
Old 26-10-17, 04:45 PM   #20
They don't on the Siemens 420 series, I have two that I have acquired and even when using them at work they are mounted on the back plate and the cables run into cable trays to leave the cabinet via cable glands.
Stuart, I'm not knocking the military, when I retired work had three, two ex army and one ex RAF, the only issue I had was their desire to take charge of everything even when they didn't have a clue what they were doing.
