Old 01-10-17, 12:34 PM   #1
jimbo
Default Stuart engine .
I have been offered a small Stuart engine and would like a bit of info . the plate says R2Y 38673 1500 rpm any body able to shed some light as to its i.d and its origin .I do not think its complete so what are they like to get bits for ?? Thanks for any info in advance ,JIMBO
jimbo is offline   Reply With Quote
Old 01-10-17, 12:38 PM   #2
Would have been something like this with cooling circulation pump.
Bearings etc are easy enough to source, parts of the R2 and other non-marine engines are a bit harder to come by.
Peter might be able to help with further information.
Old 01-10-17, 01:04 PM   #3
Sold to D Hillyard on the 7th February 1957.
Works order E9772-1587
R2Y 300W 12/18V generating plant, switchboard 10124, no mention of cooling pump.
No service details saved.
Old 01-10-17, 01:29 PM   #4
I can't find it atm but it was in one of the manuals for the R2/3, said something like Circulation pump suffix Y.
Found it......
Old 01-10-17, 01:51 PM   #5
It has been speculated that the 'Y' originally stood for yacht as a cooling pump would have been primarily required on lighting sets installed in boats as opposed to tank cooling, standard on fixed plant.
Old 01-10-17, 02:09 PM   #6
Agreed, but the day books normally mention if a pump was supplied, hence my comment.
See others that I have checked, a pump is often mentioned.
I had this book out since last week, so fairly quick to look it up.
Old 01-10-17, 02:18 PM   #7
D Hillyard was David Hillyard, he also bought 38663, another similar set on the 23rd April 1957, a bit back to front but that's what is in the book.
That one came back for a rebore on the 9th December 1969.
Old 01-10-17, 02:21 PM   #8
"Tektrik Tucker Start" comes up quite often, but I can't find much about it.
Both of David Hillyard's engines are so noted.
Any ideas?
Old 01-10-17, 04:26 PM   #9
jimbo
THANKS guys brilliant response lovely bit of interesting history .I might but this one .
Old 01-10-17, 04:32 PM   #10
As in this Hillyard?
http://www.hillyardyachts.com/index....ilingyarns.htm
