Old 29-09-17, 01:31 AM   #1
gamefarmone
Question Lister D Hopper Fastener size
I'm just finishing up my Lister D-replaced the head gasket, lapped the valves, and gave the hopper a good cleaning to open up all the water passages.
It's been some time since starting the job, and as per usual, seem to have misplaced some necessary items.
I need the five nuts that hold the hopper and valve assembly down.
You know... one minute they're there, and then they're not?
Could someone tell me what size they are, and if they're British Whitworth threads?
That thread is all but impossible to find here in the States, so may have to opt for a rethread of the bolts if I can't find the originals.
Any suggestions on what size American Standard Die to use if it comes to that?
thanks for any suggestions
gamefarmone
gamefarmone is offline   Reply With Quote
Old 29-09-17, 01:48 AM   #2
eddie78
gamefarmone
They are 5/16 british whitworth
Old 29-09-17, 05:51 AM   #3
And 3 of them are brass....
And all of them are 7/16
Old 29-09-17, 05:53 AM   #4
slatteybarn
And they are brass in the hopper to prevent them rusting up.you get some from Stationary Engine Parts 8.99 for a set of 3.
Hope this helps
Phil.
Old 29-09-17, 01:07 PM   #5
They are bigger than 5/16". I seem the recall that they are 7/16" bsw but haven't an engine handy you confirm.
Old 29-09-17, 01:23 PM   #6
miley_bob
miley_bob's Avatar
Yes certainly bigger than 5/16 BSW.
Old 29-09-17, 02:44 PM   #7
cameltank
cameltank's Avatar
Location: Mainly Hampshire but I seem to spend most of my life at Heathrow Airport...
100% 7/16"
now the question of BSW of BSF...
Mine are BSW for the thread that goes into the block.
Worth checking your own as there seems to be different varieties built out there!
I have seen BSW forced onto BSW and vice versa - not pretty.
I work for Cat who are based out of Peoria, Ill, and I got colleagues to check this for me (yes I took head bolts on a trip to HQ...)
Hope that clears it up :)
Best
Hamish
cameltank is offline   Reply With Quote
Old 29-09-17, 03:26 PM   #8
PuttPuttBang
PuttPuttBang's Avatar
Best
Hamish
? Hamish did you mean BSF ?
Old 29-09-17, 03:32 PM   #9
miley_bob
miley_bob's Avatar
Can't say I have ever come across a Lister D with BSF head studs. The only time I have seen BSF on a Lister was on the G types.
Old 29-09-17, 03:37 PM   #10
All threads are BSW
