Old 25-09-17, 12:51 PM   #1
crank
crank's Avatar
Default Lister B valve timing
Thanks martin some photos of the Gears
regards
Crank
crank is offline   Reply With Quote
Old 25-09-17, 01:05 PM   #2
Was this a question?
If it helps, with the piston at TDC you should be able to slide the cam lobe in so that both valves are just "on the rock" (i.e. making contact). As you rock the crank back and forth about TDC, the valves should close symmetrically either side. Lister did this so that the engines could be reversible without messing with valve timing.
Old 25-09-17, 04:51 PM   #3
single flywheel
Smile lister b valve timing
nice to see a cage valve B ready to run again.
Mike,
Old 25-09-17, 05:22 PM   #4
crank
crank's Avatar
Thanks for your input. I have had it running but it runs like a hit and miss. Been cleaning up all the governor parts also checking the valve timing.theirs two dot marks top and bottom on the cam gear plus maybe a makers mark
Crank
Old 25-09-17, 05:33 PM   #5
I've got a B exactly like yours, because it doesn't have a float bowl it sucks direct from the tank, it can be a little hit and miss particularly when it has no load, as does my single flywheel lister A.
Old 25-09-17, 07:27 PM   #6
Dazzla
Dazzla's Avatar
I've a got an A and a B, both from 1924 and they're quite erratic when running light and slow.
Don't panic. As Martin says, it's a feature!
Dazzla
Old 25-09-17, 07:47 PM   #7
crank
crank's Avatar
Thanks i have a lister b pulley i haven't fitted it because i have been using
that side of the shaft to start it. will have to make a starting handle for the correct side
engine no 45104 spec 14
thanks for advice
crank
