Old 22-09-17, 01:07 PM   #1
Chris Mcdevitt
Chris Mcdevitt's Avatar
Default Stuart Turner A series water pump
Hi Guys
Could anyone advise??
The little hole on the con rod/big end of a Stuart A series water pump, should this be facing down into the oil sump so when hits oil lubes the bearing or should it be at the top?? this lines up with oil way on bearing.
I am guessing facing down but want to be sure
Cheers chris
Chris Mcdevitt is offline   Reply With Quote
Old 22-09-17, 01:10 PM   #2
Up
Old 22-09-17, 01:20 PM   #3
Chris Mcdevitt
Originally Posted by skankin_giant View Post
Up
Thank you.
I got that wrong then, just did not look correct
