Old 20-09-17, 08:42 PM   #1
slatteybarn
Default Sticking rings
Hello all.
I've got a bit of a problem that I hope I can get some help with.
I'm taking 3 engines to Kettering Rally this weekend and one is my Weeks orchard sprayer,I've not touched it for over a year and due to time restrains I've just fetched it out of the shed and found that its got no compression.a quick check of the valves and they are not stuck and working.
Which leads me to think that the rings are gumed up and sticking in the piston.are there any quick fixes.a sqirt of oil in the bore has resulted in some but not a lot of compression,and I dont have time for a complete stripdown.
Phil.
Ps I know a quick fix is not the correct route to follow but it's all time will allow for now.
Old 20-09-17, 08:52 PM   #2
What did we put in our engines as lads to decoke them, we would have to find a field in the middle of nowhere because of the smoke created whilst running the engine.
Old 20-09-17, 09:05 PM   #3
Nev B
Redex , did that stuff really do anything apart from make a lot of smoke ?
Neville Bond
1940s Stuart Turner HY1
45 hp Gray Marine
Petter Mini Twin marine
Thornycroft DB2 Handybilly marine
1917? Fairbanks Morse two stroke
Nev B is offline   Reply With Quote
Old 20-09-17, 09:05 PM   #4
Could just be a dry bore, squirt of oil down the bore should give enough compression to start it and then it should be ok after a short run
Old 20-09-17, 09:14 PM   #5
slatteybarn
Thats what I'm hoping for Appletop.I shall see what happens on saturday.failing that the paying public will be prive to a full strip down in the field.
Phil
Old 20-09-17, 10:45 PM   #6
Used to blanket the street with smoke when dribbling it into carb on my Mini while revving the engine
