Old 11-09-17, 05:21 PM   #1
eddie78
Default Big end size oh er
I have acquired a lister L type very very cheap no frost damage etc....
But has zero compression because it has no conrod or piston unfortunately I havent had a chance to pick the engine up and tear into it.
it is a spec 82L 1927, on that popular auction site there is a piston and rod for sale but it is from a 104L does anybody know if this will fit did they monkey about with big end sizes etc...
Old 11-09-17, 09:42 PM   #2
At some point in production they increased the size of the crank to 2" dia to the same size as the cs.
Paul
Old 12-09-17, 09:38 PM   #3
eddie78
Paul
Any ideas what spec they changed the crank sizes
Old 12-09-17, 09:57 PM   #4
"Around 1931" according to the A>Z, Spec 101L, at which point they also changed from Split shell mains to bushes.
Old 12-09-17, 10:00 PM   #5
My 104M has a 2" crank, but that's the crank - it doesn't necessarily mean the big ends are different sizes. I simply don't know what size my big end is...
Old 12-09-17, 10:17 PM   #6
eddie78
I know the conrods got different part numbers around that time, will have to tear mine apart and have a measure
