Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Petrol Engine Section
Old 03-09-17, 06:06 PM   #1
listerlad
listerlad's Avatar
Default Fairbanks Morse not hitting and missing.
I took my Fairbanks Morse Z 2hp hit n miss along to The Bredgar and Wormshill Light Railway today and it lost compression because the exhaust valve was being kept open, so adjusted it but now it has been adjusted, it runs every beat and has no control as such over the speed. What is the correct setting of the exhaust valve?
Ollie
Lister D, Lister A, Lister CS 3-1, Bamford EG3, Ruston & Hornsby 6PB, Ruston & Hornsby 8PB, Ruston & Hornsby PT, Fairbanks Morse Z, Stuart Turner P4, Alco Featherweight.
Old 04-09-17, 05:01 AM   #2
listerlad
listerlad's Avatar
Default Fairbanks Morse valve timing
From what I can work out we have upset the valve timing. does anyone know the seetings or set up for this or where I can get the manuel for a 2hp hit n miss version?
Ollie
Old 04-09-17, 07:54 AM   #3
chrismac
chrismac's Avatar
Hi, on my dishpan there are timing marks on the cam gears, 2 dots on one and a single dot on the other that line up.
I got my manual from ebay.
If you get no joy I will see if I can find my manual and take a picture of the pages of interest.
Chris
Old 04-09-17, 08:16 AM   #4
Did you adjust the valve clearance or something else? Not familiar with the Fairbanks so don't know how it regulates the speed.
Old 04-09-17, 09:08 AM   #5
listerlad
listerlad's Avatar
Yeah changed the valve clearence, something I don't think we should of changed
Ollie
Old 04-09-17, 10:29 AM   #6
Ollie
First thing to try is to change it back and see what effect it has. The manual certainly won't tell you how to fix it.
Old 04-09-17, 01:14 PM   #7
listerlad
listerlad's Avatar
Just wondered if it gave valve clearances.
Ollie
Old 04-09-17, 02:33 PM   #8
I'm pretty sure I just tapped it so daylight could just be seen between the valve stem and rocker arm.
Have you checked that the latch isn't holding the tappet up?
Dan_pt is online now   Reply With Quote
Old 04-09-17, 03:32 PM   #9
listerlad
listerlad's Avatar
No, I will investigate tonight.
Ollie
Old 11-09-17, 08:43 PM   #10
listerlad
listerlad's Avatar
Next thought was the govener, now soaked in WD40 to see what happens. Don't think the weights where traveling in and out. Will try tomorrow.
Ollie
