Old 28-08-17, 05:53 PM   #1
crank
crank's Avatar
Default Lister B copper valve seals
Hi. would anyone know. if the copper valve seals. on a twin wheel
a/b lister. would be the same for a single wheel lister B. which has detachable
carb and Exhaust manifolds.
thank you
crank
crank is offline   Reply With Quote
Old 29-08-17, 06:55 PM   #2
crank
crank's Avatar
Default lister B
just a few photos of the copper gaskets. required
the inside measurement is 1-7/8. just wondered
if it was the same size .as the twin flywheel Lister
thanks
crank
Old 07-09-17, 05:14 AM   #3
Great North
Default Valve seals
I used those supplied by Stationary Engine Parts and seem to remember there was a diametric difference however located them both on the clamping face concentric with ports and dabbed a wee bit of silicone to hold them then entered the two valve bodies and tightened to bridge down...hey presto no leaks and suck squeeze bang blow ever since.
Great North is offline   Reply With Quote
