Old 27-08-17, 04:14 PM   #1
Default Small Lathe
Whilst having a look around the trade area at Hellingly FOT yesterday, I spotted this little lathe - it was so cheap I couldn't just walk away and leave it..
IMGA0708 by Phillip Sheppard, on Flickr
Every part has been stripped and de-greased. Great care was needed to make sure the fixings went back in the same places - every set screw and bolt is individually fitted and there are quite a range of threads!
IMGA0718 by Phillip Sheppard, on Flickr
It has cleaned up well and will make a nice display piece on a window sill in the house..
IMGA0741 by Phillip Sheppard, on Flickr
IMGA0742 by Phillip Sheppard, on Flickr
IMGA0745 by Phillip Sheppard, on Flickr
IMGA0747 by Phillip Sheppard, on Flickr
Can anyone shed any more light on it? There are no marks to say who made it anywhere - was it a watch or clock makers machine or just a model project? I would guess it's early 1900's at latest.
There are a few bits missing, like a counter shaft for the back gears but the gears will be the same as on the spindle, so I should be able to copy those with a basic indexing set up on the Myford.
Old 27-08-17, 07:10 PM   #2
You've done a nice job on that , I wonder how many hours originally went into making it with all the hand finishing needed?.
It will look nice as a display piece, apart from dusting it
Robotstar5 is online now   Reply With Quote
Old 27-08-17, 07:11 PM   #3
How big is it Phill?
Looks a nicely made unit - unfortunately without any markings, It'll take a month of Sundays browsing lathes.co.uk to get a possible ID.
EDIT; Nice little friend for it http://www.ebay.co.uk/itm/Metal-Shap...53.m1438.l2649
Old 27-08-17, 08:02 PM   #4
Not sure about the shaper, but I'd like a horizontal mill. Spent a while on lathes.co.uk earlier, I did find a few machines which resembled mine but nothing conclusive.
Many, many hours must have gone into it - some of it is very well finished, like the bearings, whilst other parts are really quite crude. It's just under 2' long.
Old 27-08-17, 08:33 PM   #5
Great thing about shapers is that you don't need specialist cutters - if you can grind up a lathe tool, you can do the same for the shaper.
My little Perfecto doesn't get used that often but is still a handy thing to have, TBH though I would only consider the one on ebay as a 'collectible' due to the lack of an adjustable height table.
No 'ANDISHAPO' in Lathes.co.uk but looks very much like the French 'Rapide Lime'
Old 27-08-17, 09:02 PM   #6
JohnD
JohnD's Avatar
Nice work Phil , it does have a very old look to it!
JohnD is offline   Reply With Quote
