Old 18-08-17, 04:58 PM   #1
Garak
Garak's Avatar
Default Flywheel Timing Marks Missing
Hi
The flywheel on my Lister D has been skimmed sometime in it's life, consequently the TDC and timing (lightening bolt) marks are missing. Can anyone remind me of the formula for calculating the 20 degree timing position using the circumference measurement of the flywheel, I had this once but for the life of me I can't find it.
I have found TDC and marked this on the flywheel.
Thanks
Martyn
Lister D 18DH 1936
X-Factor, where the bewildered are wheeled out to be sniggered at by multi-millionaires.
Garak is offline   Reply With Quote
Old 18-08-17, 06:10 PM   #2
measure circumference divide by 360 multiply by 20.
Old 18-08-17, 08:34 PM   #3
Garak
Garak's Avatar
Thanks Martin, bit embarrassed I didn't know it.
Lister D 18DH 1936
Old 18-08-17, 08:36 PM   #4
Remember what
Old 18-08-17, 09:06 PM   #5
chrismac
chrismac's Avatar
The key is either at the top or bottom for TDC, I am sure a search on here would provide the info.
Just had a check,
snip, If it helps TDC or top dead centre can be found easily by turning the flywheel against compresion .
When you feel compression and the flywheel keyway is at the bottom you have TDC
Chris
