Old 23-06-17, 08:32 PM   #1
Default Villiers C12
Does anyone know what rpm's this engine should run at please.
Old 23-06-17, 09:03 PM   #2
https://www.google.co.uk/url?sa=t&so...yghsNTM9_QFqJw
Don't panic. It's a link to the manual not some random porn site.
Old 23-06-17, 10:03 PM   #3
Thanks for the link, looks like it's 3850 rpm, just got to wait until Monday when I pick up a tacho so I can check it.
Old 23-06-17, 10:04 PM   #4
That's rated speed, I'm sure the one on my mixer runs a lot slower than that. Probably nearer 1000rpm. Can probably check if you like
Old 23-06-17, 10:07 PM   #5
Slightly different....
https://www.google.co.uk/url?sa=t&so...83p1FGIzncNPqw
Old 23-06-17, 10:13 PM   #6
So the second link has 2800 rpm rated speed, I'm still new at this stationary engine business so should I be looking for a "tickover" of 1000 rpm then higher revs when I load it up?, I'm looking for an old car type dynamo to drive at the moment.
Old 23-06-17, 10:19 PM   #7
They run well enough at lower speeds, I'd be inclined to run it at a lower speed but making sure it's running fast enough to cool itself and drive the genny easy enough, run it too slow and it'll slog and run hot.
Old 23-06-17, 10:21 PM   #8
OK thanks.
