Old 21-05-17, 07:39 PM   #1
Matt_Hedges
Matt_Hedges's Avatar
Default Cast iron fuel tank
Hi all, I have this 1930 spec 18 lister A that I got running today. When I took the tank off it was very heavy and after a close look it is cast iron. I have never seen a A with a cast tank however it defiantly looks factory done. Does anyone know why this might have this tank ?
https://youtu.be/xJonwdQt5Ac
Matt
1936 reverse rotation Lister D, restored lister H1, 1929 shaft drive Lister D, unrestored lister H1, Bamford EV1 1944, Ruston 6PB 1938, Lister H2, Norman T300 lighting set
Matt_Hedges is offline   Reply With Quote
Old 21-05-17, 07:49 PM   #2
I'm thinking that it's definitely not defiant!
I don't know about your cast tank but I do know that it would be a good idea to shorten the HT lead and get it off the exhaust pipe. You don't want that to melt through and short the magneto.
Old 21-05-17, 09:28 PM   #3
Sure it's cast and not just made from heavy steel plate?
Old 21-05-17, 10:26 PM   #4
Matt_Hedges
Hi, I did amend the HT lead after the video as I thought the same thing. I did think that to start with but it does look cast to me. I might be wrong and will double check.
Thanks
Matt
