Old 05-05-17, 05:28 PM   #1
uncle pete1
Default Stuart Turner P5
hi i own a stuart turner p5 which i need a head gasket for please also under neath the carb there is a small brass container with a fine mesh over it on the side of tis container is a small plug ,,any ideas what its for please
many thanks
uncle pete1 is offline   Reply With Quote
Old 05-05-17, 05:33 PM   #2
How many head nuts does it have?
The tin is a drip tray.
WW1 ABC, Brockhouse Spryt, Norman SC, Sattley TA, Scott SE, Stuart H1, K & WD, Villiers WX11
Old 08-05-17, 10:37 AM   #3
Yes well what you can do is fit some 1/4 copper pipe to the 1/8th fitting in this drip tray and run any fuel spills elsewhere .............I have an idea that the bronze gauze was an anti fire precaution, not a bad idea if you get a leaking carb and a bilge with fuel in it.
winchestergoose is offline   Reply With Quote
