Old 04-11-17, 08:33 PM   #21
Still in the back of the car but looks good - turns over with compression and no obvious nasty noises.
Cant reconcile those flat belt pulleys with original assumed application by Fairmile but who knows?
Old 05-11-17, 02:37 PM   #22
A few pics after a quick clean-up.
Old 05-11-17, 02:46 PM   #23
Is the twin pulley standard and what would it have been used for.
Old 05-11-17, 04:07 PM   #24
From Peter:-
32514 sold 15th August 1941 to Fairmile Marine, part of a larger order for 18 units.
Pump lubricated, Lancashire Dyno & Crypto dynamo 89Y506 and switchboard 5186. Miller magneto.
If they were used on Fairmile MTB's, then they would have used petrol from the main tanks, obviating the need for petroil mix.
Your guess is as good as mine on the pulley which by the has a 'V' between the two flat belt areas.
Old 05-11-17, 04:25 PM   #25
I seem to remember something about twin dynamos?
I'll check tomorrow.
Old 05-11-17, 05:46 PM   #26
Thinking about this again, I think they had two engines per dynamo in the setup.
Old 05-11-17, 06:04 PM   #27
That was the case for the P5LY ASDIC sets http://www.stationary-engine.net/for...76&postcount=1
Old 05-11-17, 06:37 PM   #28
Looks nice Nick, have you worked out which Magneto it has yet?
Old 05-11-17, 06:42 PM   #29
Peter's info says Miller.
Old 06-11-17, 05:04 PM   #30
"Generally as Plant 32502"
