Old 11-04-17, 04:50 PM   #11
I suspect Phill wasn't being entirely serious; could be 32:1 if you take 2 gallon of petrol and add 1/2 pint of oil, or 31:1 if you start with the oil and make it up to 2 gallons total - see?
Don't stick for him, let him dig his way out unaided
Old 11-04-17, 07:32 PM   #12
Exactly. Neil I was referring to the methodology you use to make the petrol/oil mixture. There is a difference if you take the addition approach, or the volumetric approach. Plus I was having a little fun, hence the emoticon.
Old 11-04-17, 07:47 PM   #13
Philip,
If you remember correctly you and I discussed on Saturday the lack of understanding regarding the injection of any use of light heartedness :whistle
Old 11-04-17, 08:13 PM   #14
I was more interested in how you work it out, the actual maths if you like.
To mix fuel I use a litre mixing can, that once full with petrol has a scale against which you add oil.
For larger quantities I add one shot mixers to the appropriate quantities of petrol.
(for which I need the maths)
Then again for smaller tools like chainsaws and brush cutters I just use Aspen, aspen 2 for the strokers and aspen 4 for the proper tools.
Old 11-04-17, 08:27 PM   #15
Philip,
Indeed, a little fun and a smile here and there, makes the day go round. There's far too much seriousness in the world.
Old 11-04-17, 08:29 PM   #16
That sounds like both are addition methods, ie you are adding a known amount of oil to a known amount of petrol.
There are lots of 2 stroke oil/petrol mix calculators on the www.
Old 11-04-17, 10:43 PM   #17
ScottUK
Hi Neil,
The maths is simple, just divide your required total qty in litres by the ratio to give the oil req'd.
So for 10 litres at 50:1 , you'd get 10 / 50 = 0.2l /200 ml of oil.
For 5 litres at 32:1 you'd get 5 / 32 = 0.156L / 156 ml of oil.
Best regards,
Scott
ALCO featherweight genset, Villiers/Swan genset, JAP model O genset,
JAP S80 Worthington pumpset, JAP 2A Worthington pumpset, Stuart Turner R3ME, Norman T300 Mk1
ScottUK is offline   Reply With Quote
Old 11-04-17, 10:48 PM   #18
Originally Posted by ScottUK View Post
Hi Neil,
Best regards,
Scott
Thanks Scott, and just to make it idiot proof, for example 1 you would add 200ml oil to 10 litres petrol, not add the oil and then add petrol for a total of 10 litres ?
Old 11-04-17, 10:54 PM   #19
ScottUK
Yep, you've got it, you'd add the 200ml to the 10 litres.
Happy mixing! :)
Best regards,
Scott
Old 11-04-17, 10:59 PM   #20
Happy mixing! :)
Best regards,
Scott
Thanks for confirming that.
For now I'll just be mixing it a litre at a time, until I find what works for me.
I'll also need to sort out a tanks for the P5.
I have two that I don't like much, not sure if I want to try making one I like
