Old 10-04-17, 09:56 PM   #1
Default Fuel oil mix
What fuel mix do I run my fully rebuilt P5 on, engine will probably never run a full loads and hopefully never at full revs.
I'm sort of thinking 32:1 for a start ?
Old 10-04-17, 10:11 PM   #2
50:1 by the book. 1/3 pint to 2 gallon.
For light load or times with a lot of idle Stuart say more oil could be added, up to 1/2 pint in total.
Old 10-04-17, 10:47 PM   #3
By my (possibly) suspect maths 1/2 pint in 2 gallons is actually 32:1 is it not ?
Old 10-04-17, 10:53 PM   #4
Near enough I would say.
Thats running SAE30 not quality modern 2 stroke oil.
Old 10-04-17, 11:39 PM   #5
Does it make a difference, was going to use standard dinosaur type 2 stroke oil
The other choice, as have a litre is Aspen ready mix 2 stroke fuel, just thought it may be a bit thin for an old engine design.
Old 11-04-17, 07:03 AM   #6
Modern stuff mixes better and burns cleaner than straight oil, the oils these were designed to run on was in use 90 years ago now.
Old 11-04-17, 09:12 AM   #7
Silver Knight do 2 stroke oil in gallon (ish) cans. I found it very reasonable price compared with other 2/ oils. (If you can get it.) I use it in TVO mix.
Old 11-04-17, 01:35 PM   #8
Well it depends on how you actually do it .....
Old 11-04-17, 04:38 PM   #9
Explain how you work it out then.
Old 11-04-17, 04:48 PM   #10
I suspect Phill wasn't being entirely serious; could be 32:1 if you take 2 gallon of petrol and add 1/2 pint of oil, or 31:1 if you start with the oil and make it up to 2 gallons total - see?
