Old 10-04-17, 09:30 PM   #1
EarlBathurst
EarlBathurst's Avatar
Default ListerA No50396
Hi all. Thought you might like a look at my latest toy.https://youtu.be/6q1KoPXOXvA
Its number 50396 is all I have as the spec plate is missing. I think its an A spec 14. Can anyone confirm that. ?
Karl.
Old 11-04-17, 06:42 PM   #2
single flywheel
Smile lister a no 50396
Hello nice to see another lister a single flywheel running again. I have a number of these models. Will have a look at my numbers to see what you have.
Mike
Old 11-04-17, 06:58 PM   #3
Karl,
I have a Spec 53(13) whose serial no is 42385.
Old 11-04-17, 08:32 PM   #4
single flywheel
Hello again looking at Davids know your lister book page 17 the first spec 14 engine 43996 was built 28/11/24. Their is quite a mine field of engines around because it was around that time twin flywheel engine were also still fitted with cage valves.
Mike.
Old 12-04-17, 12:29 PM   #5
EarlBathurst
Sussed it !
Doreen has had another look at the logs and come back withe the following;
Lister A14, 50396 supplied to Stanley Engineering Co Oldfield Bath* on 23-10-1925.* It also has P Set (not sure what this means??)
Old 12-04-17, 01:17 PM   #6
Pump Set ???
Old 12-04-17, 03:47 PM   #7
EarlBathurst
Originally Posted by air-cooled View Post
Pump Set ???
Thats my thoughts.
