Old 24-03-17, 07:30 PM   #1
Default Identifying your P5
Well as we have a Stuart Turner section I thought it was worth knocking this up as there seems to be confusion over the Stuart P5.
Lets start from the beginning with the P4, the P4 was introduced in 1928 and replaced the P3, it was a more robust design featuring roller bearings through out.
The P4 (Bore and Stroke 2 3/8 x 2 3/4) was uprated to 3HP to produce the P5 (Bore and Stroke 2 3/4 x 2 3/4)
This early P5 looks identical to the P4 with 4 bolt cylinder head and bolt on cast iron expansion chamber.
This early P5 was also used as the companies 1st marine engine the P5M, and I will refer to it as the "4 Bolt P5" for it's 4 stud cylinder head.
P4
4 bolt P5M
The P5M was later redesigned due to Stuart finding a good market with their marine engine
There were lots of changes to the top end, a 6 bolt head and a water cooled expansion chamber are two of the identifying features of the "6 Bolt P5"
Sadly I don't really have good pictures of the 6 bolt P5M
I am not sure if both the 4 bolt P5 used in industrial form for gensets etc and 6 Bolt P5M were in production at the same time.
The P5X was the industrial version of the 6 bolt P5, it had a thinner flywheel, the water cooled expansion chamber tower was removed/blanked off and replaced with a cast iron expansion chamber. Zwicky fuel bowsers were a user of these.
Pinched a photo from DanPT sorry....
The 6 Bolt P5's can also be found on generator sets with a heavier flywheel than the P5X
Anyways it's a bit brief but covers the main P5s out there, I hope it helps....
WW1 ABC, Norman SC, Sattley TA, Scott SE, Stuart H1, K, R3 & WD, Teagle B2, Villiers WX11
Old 24-03-17, 07:58 PM   #2
Thanks for that, your first pic is pretty much what i have, may even be identical, as only point of difference is the mag chain cover, mine is missing, but the only one I have seen in the flesh was slightly different.
Serial number for this engine is 13288, engine on display at Museum of Power Langford, (nr Maldon)
My own engine is number 13011 so fairly close the one shown.
Old 24-03-17, 08:12 PM   #3
Once had a P5M same as the second photo. 1932 that was dated at.
Old 24-03-17, 08:27 PM   #4
That is a later timing cover with the dip stick, here is an earlier one with sight oil level well.
IIRC yours is a P5LY? which should look something like this:
Old 24-03-17, 08:30 PM   #5
Quite an interesting segment of ST history the initial marine engines.
In 1930 the marine engine was born after an extremely short period of gestation.
It happened in this way :- Mr. Neble, a Danish gentleman, came to see us. He told us he wanted a 3 b.h.p. engine for pleasure park boats, could not find one that was any good and would we provide him with 50 engines within four weeks? We took a deep breath and said “Yes”!
The P.5 cylinder, the circulating pump and the other details were designed, the patterns made, castings produced, engines machined, built and tested and the first delivery of 12 engines was taken down by Mr. Cossins in the Works lorry and delivered on the appointed day (much to the annoyance of the boat builders, who were not nearly ready for them). Everyone concerned had put their backs into it and done a little more than their best.
Afterwards, of course, the marine engine gradually evolved, marine clutch, gearbox and other frills were added and the P.55 came along.
Old 24-03-17, 08:55 PM   #6
Nope, just a plain P5, flat rear cover with no pumps, oil or water.
Old 24-03-17, 08:58 PM   #7
Ah ok, then either the sight oil lever or dipstick cover will suite.
Old 24-03-17, 11:06 PM   #8
They would indeed, but having spent a long while looking, and being disappointed
or having some one try to bend me over I said no more, found a piece of 5/16" steel plate and made my own. Level screw instead of a dipstick though.
Old 24-03-17, 11:14 PM   #9
Have you tried the likes of stationary engine magazine and the Stuart Turner information exchange?
I made one out of plate for one I had in college we fitted with a electronic governor. Done the job.
Old 24-03-17, 11:24 PM   #10
Stuart Turner exchange, is that the Yahoo group thing ?
After someone asked £100 for one, dipstick missing I sort of lost interest in buying one.
Then a forum member offered one, but never followed through and doesn't answer PM's, that decided me to make one.
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
