Old 27-06-17, 10:13 PM   #61
https://www.youtube.com/watch?v=845v_iMspL8&sns=em
https://www.youtube.com/watch?v=Xv6NutYMg0Q&sns=em
Hopefully those two videos will explain what I mean...
first on was my Amanco
Old 27-06-17, 10:16 PM   #62
Could you (or anyone else) give me the 'science bit' on that Rob?
EDIT; Not taking the p*** - genuinely interested.
From my own observation with the Amanco exhaust is it does absolutely cock all to silence the engine and about all it does is stop rain getting in and gives a certain amount of back pressure in doing so.
Old 27-06-17, 10:28 PM   #63
Got to admit that does sound a tad strident - I'd forgotten how much l don't like the non hit-and-miss versions!
Old 27-06-17, 10:42 PM   #64
Like a bag of bricks in a 205lts drum......
Old 28-06-17, 12:20 PM   #65
Shifty1962
Shifty1962's Avatar
When I first got it the governor springs had been removed I assume to slow it down. I fitted them and adjusted the weights so that at full travel the throttle plate was virtually closed. The springs with the weights at rest are virtually doing nothing but with no slack or tension if that makes sense.
Originally Posted by Dazzla View Post
Try slowing the engine speed down. Throttlers do run best at speed, but they can be slowed down and when set up right and running light they don't fire every 4th stroke. Even throttle governing allows a few turns without firing. Governing is about managing engine speed, not power per-se.
Dazzla
Shifty1962 is offline   Reply With Quote
Old 28-06-17, 12:22 PM   #66
Shifty1962
Shifty1962's Avatar
I think that is a fairly accurate technical summation of my standard exhaust
When all is said and done its just an open pipe with a rain hat.
Old 28-06-17, 07:39 PM   #67
Dazzla
Dazzla's Avatar
Try setting the governor so the butterfly is fully closed at about 3/4 travel.
Dazzla
Old 29-06-17, 09:56 AM   #68
Shifty1962
Shifty1962's Avatar
OK I'll give that a go this weekend.
Dazzla
