Old 05-12-16, 09:53 PM   #1
allan grieve
Default A and B parts
Having a clear out any one looking for parts
Allan
Old 14-12-16, 07:41 PM   #2
rusty lumps
Hi Allan I am looking for the linkage from the flywheel governor to the carb,the little top on the fuel chamber and maybe a fuel pump. This is for a lister A.
Regards kev
rusty lumps is offline   Reply With Quote
Old 14-12-16, 09:13 PM   #3
single flywheel
Smile lister A B parts.
Hello Alan I know you said lister a b parts but Derek is going to look at a lister M later in the week missing a fuel tank just wonder if you have anything lying about, Mike Watt,
Old 14-12-16, 10:09 PM   #4
allan grieve
Default Lister M
Hi Mick
Take it is the one Steven sent me photos of nice engine I have two L type engines to look at, not sure how complete they are, will get back to you after I have viewed them. The christmas crank up at Balboughty is on the 27th
Old 14-12-16, 10:28 PM   #5
allan grieve
Default lister A parts
Regards kev
Have sent pm
Old 16-01-17, 08:10 PM   #6
Dan_the_man
Hello, do you have any main bearings for a Lister b type? Mine is a type 17 single flywheel but any should do. Thanks.
Dan_the_man is offline   Reply With Quote
Old 16-01-17, 10:32 PM   #7
allan grieve
Default Lister B
will have to check will be at the work shop Wednesday night are you looking for any other parts
Old 19-01-17, 10:29 PM   #8
piston-broke
piston-broke's Avatar
Hi i am looking for the gungeon pin for a B type 1" x 4" would consider anything over 4" as I can grind it down in the lathe with a tool post grinder
Lister CS 6HP radiator cooled - lister L 7HP hopper cooled - Lister DK genuine - lister B hopper
Petter Apple top 3HP - Petter Acorn top 1.5Hp - BSA sloper - Enfield Diesel 350 generator
piston-broke is offline   Reply With Quote
Old 19-01-17, 11:08 PM   #9
allan grieve
Default Lister B
Will have a pin for your B have to check condition and then get back to yoy
