Old 07-07-16, 06:57 PM   #11
If you clean carefully around the square base serial and model no's should appear.
Old 07-07-16, 06:59 PM   #12
ant
Hi
Pics of frost damage after taking a good inch of grime and muck off
Ant
ant is offline   Reply With Quote
Old 07-07-16, 07:11 PM   #13
ant
Hi Martin
Only number I can see is under the points that brass plate if that what you mean I can see b2 and think ma if that helps
Cheers ant
Old 07-07-16, 07:58 PM   #14
should be a whole list of numbers along the sides below the magnet. this includes the date of manufacture I will photgraph a similar magneto this weekend.
Old 07-07-16, 08:07 PM   #15
ant
Hi martin
Cheers for the reply
Only thing I can see saw far is I direction arrow if I get a hour tomorrow I will see I can clean it further see if I can see anything else
Cheers ant
Old 18-07-16, 09:05 PM   #16
ant
Hi everyone
Thought since it was nice day I've unloaded the lister and and had couple of hours in giving it a good jet wash and partley dismantled it to see how good the bore is wich is quite good and dosent seem to be any wear and goes same for the bearings
While is was giving it a good jet wash in the sump I found a couple thin metal fragents can't find saw far were there as all the piston ring are intact only place I haven't really checked due not stripping it yet is the govener system as it is very stiff and not moving the push rods much
I am also asuming that was probably originally that it part of mixer or crusher set as been washing loads of pebbles
Hopefully have a couple of hours tomorrow and strip the govener system and hopfully there's nothing broken there I'm also suprised how much paint work is left including the arrow for directions
Ant
Old 18-07-16, 09:18 PM   #17
ant
Will upload photos later when the forum let's me
Ant
Old 18-07-16, 09:53 PM   #18
Numpty
Its an M-L, type KP1 and original to the engine.
Old 16-08-16, 04:39 PM   #19
ant
Hi everyone
I've had couple of hours in cleaning up a few bits and replacing the valve stem as it completely had its days
I've also managed to find searial number on the flywheel rim which is 230024
If any can help me in dating it will be much appreciated
Cheers ant
Old 16-08-16, 05:04 PM   #20
January 1935.
