Old 28-06-16, 05:11 PM   #1
Terry1943
Default Fuel pipe
Hi all
Getting round to finishing my "L" at last , can you advise on the OD Dia of the copper fuel pipes, feed and overflow, the tank fittings are 1/4 BSP and the pump is 3/8,
Thanks
Terry
Terry1943 is offline   Reply With Quote
Old 02-07-16, 09:30 PM   #2
Scott
Hello Terry
If no-one replies I'll measure in a couple of days.
Cheers Scott
Old 03-07-16, 01:42 PM   #3
Terry1943
Many thanks Scott.
Old 07-07-16, 08:49 PM   #4
Scott
Hello Terry
I finally got to the bigger Lister spot in the shed
For the two pipes at the pump I got 7.82mm, which is roughly 5/16", and the overflow is 12.62 which is roughly 1/2". All OD.
I don't think the overflow pipe fitting should be 1/4 BSP into the tank.
Cheers Scott
