Old 02-06-16, 12:56 PM   #1
listert
Default Lister L shooting flames
Hello guys.
had my lister l running at nuenen all weekend.
but sundaynight she suddenly died out.
there was a massive bang with bleu flames shooting out of the carb and exhaust
since then i can,t get it started.all that happens is one big bang!
i tried 4 different plugs and cleaned out the carb.
get a blue spark with almost every plug.
timing seems ok as the points open just before tdc.
i,m lost at this point
regards Brian
lister d 1952 wolseley wd9 wasserknecht waterpump lister L type cunewald 1h65
listert is offline   Reply With Quote
Old 02-06-16, 02:28 PM   #2
ListerHA2
ListerHA2's Avatar
Any compression when turned over slowly?
Old 02-06-16, 02:33 PM   #3
listert
yes compression is still very good.
when cranking slowly the intake sucks and the exhaust blows just as it should.
valves don,t leak either
Old 02-06-16, 02:39 PM   #4
It sounds a bit like fuel starvation; my Lister M bangs very loudly as the fuel runs out. Try cleaning the carb jet out...
Old 02-06-16, 02:42 PM   #5
ListerHA2
ListerHA2's Avatar
Any chance the timing has shifted somehow? Points short or other mag fault.
Old 02-06-16, 02:47 PM   #6
listert
i thought it could be a fuel issue to.
but i cleaned the entire carb out.
the jet is clear.
maybe it,s the mag but a first sight everything looks ok.
it has the orginal ml on it
regards Brian
Old 02-06-16, 03:32 PM   #7
might be the condenser. a typical issue with the lucas mags (i realise your mag is another make, but the issue is still relevent) is that as the condenser begins to fail, it mucks up the timing, so whenever you check the points, its spot on, but the actual spark time changes, causing bangs through the intake and exhaust due to being off time. I've seen it a few times with Lisster A's and D's, leads to much head scratching.
Old 02-06-16, 03:56 PM   #8
listert
i,m a little careful of taking the magneto apart.
does my magneto have a condensor?
it,s a chain driven square ML
Old 02-06-16, 05:49 PM   #9
audiobull
Video?
audiobull is offline   Reply With Quote
Old 02-06-16, 07:55 PM   #10
listert
i will take it outside first
it,s in the back of the shed surrounded by flammable things
