Old 23-06-14, 08:07 AM   #1
pascal22
pascal22's Avatar
Default New trolley
Hi all,
here are photos of my new trolley for my ''L'' type,
I hope it'll be enought strong for his weight !!!
It's not the finished version, just to have a look
regards
pascal
pascal22 is offline   Reply With Quote
Old 23-06-14, 09:55 AM   #2
Very nice Pascal. Always fancied that type of covered trolley myself. (still no luck with your items-be in contact soon)
Old 23-06-14, 09:55 AM   #3
Landy
Landy's Avatar
Looks very smart!
Chris
Landy is offline   Reply With Quote
Old 23-06-14, 10:54 AM   #4
POTP
POTP's Avatar
I like it, very continental
Gareth
POTP is offline   Reply With Quote
Old 23-06-14, 04:30 PM   #5
Lovely trolley, Pascal. I would recommend putting a tie bar from the bottom of the front pivot to the rear axle. It will help to keep the steering axle vertical.
Old 23-06-14, 05:10 PM   #6
JamesB
JamesB's Avatar
Beautiful trolley pascal. I'm planning to build something like that for my bamford lighting display
A lonely Lister DK
JamesB is offline   Reply With Quote
Old 23-06-14, 07:31 PM   #7
pascal22
pascal22's Avatar
Many thanks to you all,
I'm very pleased with the answers of my first one public.
To be continued...
Pascal
Old 02-05-16, 04:16 PM   #8
pascal22
pascal22's Avatar
Hi all,
back on my trolley, I've spent my saturday afternoon to disassemble it and rescrew all the moving nuts, I've also welded all of them against unexpected unscrewing. And optional I also welded one of my fingers...
Welded abutments for back wheels.
I also followed your advice Phillip, I fixed a steel bar from the back axle up to the pivot of the front and you were right Phillip, the trolley is more stable...
cheers
pascal
Lister L, Lister J, Lister B, Lister CS 5/1, Bernard w2, Tosello AR, Le Robuste, Crossley 1060.
Old 02-05-16, 04:27 PM   #9
David
Hi looks good,
Just one thing how much clearance do you have between the top of the large wheels and the back of your hand when the crank handle is turned?
from the photos it looks like it might be a bit close.
David.
David is offline   Reply With Quote
Old 02-05-16, 07:40 PM   #10
pascal22
pascal22's Avatar
Judicious comment David,
I had a try with the starting handle in automn when I painted the engine
And fortunatelly the engine has a big base, 17cm high.
But you're right David, starting handle is close to the large wheels.
Idem for the flywheels, I remember about 2 or 3cm between the rim of the flywheels and the legs of the roof.
It's a bit tight for the engine but because of the down direction exhaust which must come back either in the center or in the front of the trolley and the water tank must found his place too...
It's like a housing crisis to me
But I'll do my best to achieve.
Many thanks David
Pascal
