Old 25-05-13, 03:00 PM   #1
The wild eye
The wild eye's Avatar
Default Cracks in Bakelite fittings
An old trick taught to me many years ago by a very clever AA man .
When you are faced with a crack in your distributor cap ( this case a lister hovis mag top ) you can seal the crack using Nail varnish from your lady friends handbag .
Any colour will do but I just happened to find some black while rummaging around in Angelas hand bag
The varnish is painted on thickly enough to fill the crack and thus seal it from the ingress of moisture .
Old 25-05-13, 03:14 PM   #2
Statman's Avatar
Handy little tip there,
But I prefer red myself
Ruston PT, Bamford EG1, Villiers Mar-Vil, Petter A,A1,AA1, 3 Lister D's, Stuart P5 and Bsa Charging Set
Statman is offline   Reply With Quote
Old 25-05-13, 05:53 PM   #3
Very good tip will use time !!!
villiers24 is offline   Reply With Quote
Old 26-05-13, 01:25 AM   #4
Karragullengine's Avatar
That is a very good thing to know. Black nailpolish? Go on be honest, it's your isn't it?
Old 26-05-13, 08:54 AM   #5
Combustor's Avatar
Default My crack habit.
If the break still seems clean, I have several times resorted to Super Glue. When the first application is hard dry, you can run another bead along it to fill any small openings. Allow drying time and repeat as needed. In a day or 2 you can carefully scrape or sand away any surplus. Works for me so far. Combustor.
Old 29-05-13, 01:40 PM   #6
stover600's Avatar
Nail varnish in mid brunswick green perhaps !
stover600 is offline   Reply With Quote
Old 17-06-13, 08:54 PM   #7
Used the same trick on a defunct rotor arm off a SCAMMELL EXPLORER many years ago at SELLINDGE RALLY
This kiddies Explorer had packed up through lack of sparks, found the points sparking away so worked back to the resistor in the rotor arm. Just dug it out, stuffed a bit of copper wire in the hole it left and sealed it over with nail varnish.
Our new friends grin put a cheshire cat to shame
I think the moral should be
never question the value of the contents of the guvnor's handbag
oldironbloke is offline   Reply With Quote
