Go Back   UK Stationary Engine Forum > Member's Area > Events & Rallies Information Section > Rally Hints & Tips
Old 10-11-12, 03:35 PM   #21
Karragullengine
Karragullengine's Avatar
Originally Posted by engine lover View Post
Looks like the most engines that develped fire are petrol ones!!!!
Actually before electricity came to this area all waterpumps where powered by diesels and in summer on really hot days my dad remembers many a diesel engine burning. We're talking around the 40-45 degrees celsius which is 104-113 Fahrenheit
Old 11-11-12, 07:57 PM   #22
engine lover
engine lover's Avatar
In malta the temp in the summer and in the sun will be around 60 degrees celsius.......
Gardner 6LXB,6LW,PetterAC1Z,AP1,PH1,PA2,A1,AC1ZS,R & H 2VSO,2YWA,2VTO,1VTH,1HR, Ducati IS7, Lister CS,LD1x2, National DSSh, Bradford-Sanders, Russell Newbery Bernard W110, villeirsmk12x2, JAP 55
engine lover is offline   Reply With Quote
Old 12-11-12, 04:12 PM   #23
Originally Posted by novo View Post
Good point Peter. I never considered taking an extiguisher to a rally.
Several rallies mention on the entry form that an extinguisher must be in prominence alongside the engine, very rare that they are though and nobody queries it. Usually have one by my chair, or in the back of my van if it is with my exhibit.
Old 12-11-12, 05:09 PM   #24
I started dragging an extinguisher around when I first showed the L'boro because it is a gas engine, although it's probably no greater risk than any other.
I always have extinguishers to hand in the garage and workshop - it's so easy to start a fire, and so much to lose if a little flame is allowed to develop into an inferno!
Old 26-01-13, 03:30 AM   #25
andybat49
Having done fire course's at work I consider it a rule of thumb to have a good quality fire extinguisher alongside my exhibits and always have. Personally I think it should be mandatory and the safety officers at rallies should enforce it. It is after all far too easy for someone to get burned as a result of a fire. It doesn't have to be one of us engine men but quite easily a member of the public that gets hurt.
andybat49 is offline   Reply With Quote
Old 26-01-13, 03:39 AM   #26
GreyFergy101
GreyFergy101's Avatar
Don't think there is a fire extinguisher in the shed where I work on engines.
Tractors are like cake... There is always room for more!
If it ain't grey it ain't worth the pay!
If you're a geriatric banana loader owner clap your hands!
GreyFergy101 is offline   Reply With Quote
Old 26-01-13, 04:41 AM   #27
miller
miller's Avatar
Do I need a trip over there to give you guys a few fire fighting tips and what types of fire extinguisher to use on the different classes of fire
Here is a freebie
Choosing Fire Extinguishers
Identify the type of materials in the area
Class A: SOLIDS such as paper, wood, plastic etc
Class B: FLAMMABLE LIQUIDS such as paraffin, petrol, oil etc
Class C: FLAMMABLE GASES such as propane, butane, methane etc
Class D: METALS such as aluminium, magnesium, titanium etc
Class E: Fires involving ELECTRICAL APPARATUS
Class F: Cooking OIL & FAT etc
Types of fire extinguisher
9L water fire extinguisher Water Fire Extinguishers:
The cheapest and most widely used fire extinguishers. Used for Class A fires. Not suitable for Class B (Liquid) fires, or where electricity is involved.
AFFF foam fire extiguishers Foam Fire Extinguishers:
More expensive than water, but more versatile. Used for Classes A & B fires. Foam spray extinguishers are not recommended for fires involving electricity, but are safer than water if inadvertently sprayed onto live electrical apparatus.
Dry Powder fire extinguishers Dry Powder Fire Extinguishers:
Often termed the ‘multi-purpose’ extinguisher, as it can be used on classes A, B & C fires. Best for running liquid fires (Class B). Will efficiently extinguish Class C gas fires, BUT BEWARE, IT CAN BE DANGEROUS TO EXTINGUISH A GAS FIRE WITHOUT FIRST ISOLATING THE GAS SUPPLY. Special powders are available for class D metal fires.
Warning: when used indoors, powder can obscure vision or damage goods and machinery. It is also very messy.
CO2 fire xtinguishers CO2 Fire Extinguishers:
Carbon Dioxide is ideal for fires involving electrical apparatus, and will also extinguish class B liquid fires, but has NO POST FIRE SECURITY and the fire could re-ignite.
Wet chemical
Specialist extinguisher for class F fires.
For Metal Fires: A specialist fire extinguisher for use on Class D fires - metal fires such as sodium, lithium, manganese and aluminium when in the form of swarf or turnings.
Colour Coding
Prior to 1st Jan 1997, the code of practice for fire extinguishers in the UK was BS 5423, which advised the colour coding of fire extinguishers as follows:
Water - Red
Foam - Cream
Dry Powder - Blue
Carbon Dioxide (CO2) - Black
Halon - Green (now 'illegal' except for a few exceptions such as the Police, Armed Services and Aircraft).
New extinguishers should conform to BS EN 3, which requires that the entire body of the extinguisher be coloured red. A zone of colour of up to 5% of the external area can be used to identify the contents using the old colour coding shown above.
I am a Station officer in the New Zealand Fire Service but I have looked at your standards and very similar to ours in NZ hope it helps
Dave
miller is offline   Reply With Quote
Old 26-01-13, 02:29 PM   #28
jmcgrath
jmcgrath's Avatar
So class B and class C are the ones I Will chose.
James
Too many engines to list
Old 26-01-13, 02:34 PM   #29
Magnesium?
Old 26-01-13, 04:32 PM   #30
AlandEi2
AlandEi2's Avatar
I carry a couple of dry powder ones in the camper... thanks for the reminder Peter... they are just five years old now.
Alan.
1941 Lister D - 1939 Lister A and Stuart Generator (in progress) - 1950's BSA Field Starter - [I]all protected by electrickery, razor wire, various man traps and a rabid Yorkie... [/I]
AlandEi2 is offline   Reply With Quote
