Go Back   UK Stationary Engine Forum > Member's Area > Events & Rallies Information Section > Rally Hints & Tips
Old 03-09-12, 01:42 PM   #11
PuttPuttBang
PuttPuttBang's Avatar
Originally Posted by novo View Post
Don't forget the starting handle!!! I have two Bamfords & when i pack up for a rally the starting handle is always with the one i'm not taking.Good luck with the first rally Exciting stuff.
Up to now I've always started it on the flywheel, but sods law I'll need the handle when the chips are down !
Old 03-09-12, 03:12 PM   #12
Grendel
Grendel's Avatar
I am sure that others will help you if you run out of fuel or have a small problem.
Good luck.
Hubert
Old 03-09-12, 03:14 PM   #13
Probably a good idea to get there in plenty of time and introduce yourself to the engine steward when you arrive, before you set up. You can explain that it's your first rally and ask all the important questions like how far back from the barriers your engine needs to be, where the water is for topping up, where the toilets are, etc.
Also, you'll probably know this already but don't leave your engine running unattended (even for a few minutes). I've seen this happen occasionally where people don't realise and go off for a wander, so I thought I'd better mention it just in case! We don't want you getting 'drummed out of the brownies' on your fist day! All the best and have a good time
Old 03-09-12, 03:27 PM   #14
Can you now work out fuel consumption roughly? I normally run my engine with a pint of petrol in the tank, and see how long it will run on that, and work from there.
Cheers Steve
Old 03-09-12, 05:35 PM   #15
PuttPuttBang
Cheers Steve
Thanks Steve, that's a good idea, I would do, but I've left it a bit late in the day unfortunately, only 10 days until we depart, and not much free time before then I'm afraid.
Old 03-09-12, 05:38 PM   #16
PuttPuttBang
I know, I've been trying to train my fairer half on the niceties of LT magnetos, so she can hold the fort if I need to pop off for any reason. I got as far as how to turn off the engine in an emergency, but that's about it.
Old 03-09-12, 06:50 PM   #17
Originally Posted by PuttPuttBang View Post
Peter what sort of RPM do you run at out of interest, as I imagine that has a bearing on fuel consumption ?
It's how much work the engine is doing, rather than the speed it runs at, but there is a correlation between engine speed and mechanical losses, especially with air-cooled engines with cooling fans.
The Ruston runs just under 400rpm.
Old 03-09-12, 07:09 PM   #18
The first rally of many I'm sure, enjoy it!
There has already been another thread on what to take to a rally and so on, but might I add... make sure you have a display board out with information on the engine and your name.
I often have things like period oil cans with my engines, but the rest of the clutter I try to keep out of sight.
All the best,
Old 03-09-12, 07:17 PM   #19
AndrewLincs
AndrewLincs's Avatar
Hi Mark,
I remember my first rally. My engine (a 6PB) hitched a ride in a friends trailer and had mag problems on the field. But it was a good day and there have been many more since!
I keep my rally kit in a couple of supermarket veg crates, so all I have to do is load them in the car. I have added things as I find I need them and they stay in the crate ready for the next outing.
Good luck, enjoy, and tell us all how you got on...
Andrew
Apparently, you can polish a turd ...
AndrewLincs is offline   Reply With Quote
Old 03-09-12, 08:40 PM   #20
PuttPuttBang
All the best,
Thanks Phil, I have a display board, and picked up some excellent items at GDSF, including period oil and fuel cans, and can you believe, a genuine Ruston and Hornsby watering can, for filling the hopper. Well, actually it was an old watering can, which I have painted green to match the engine, and am about to put some spare Ruston transfers on, courtesy of Ray Hooley. (pictures to follow)
