Old 27-01-12, 12:13 AM   #1
zakyboi
zakyboi's Avatar
Default freeing seized valves
hello chaps/chappesses,
restoring my d right now and the valves have decided they dont want to budge (even if everything else moves!) so, how can i free them?
thanks .
Me and my D, happy as can be!
zakyboi is offline   Reply With Quote
Old 27-01-12, 12:25 AM   #2
Penetrating oil and gentle tapping, usually go ping (if they are stuck open) with not much effort.
Old 27-01-12, 10:20 AM   #3
Listermaniac
Banned
I had to free the valves on my 6cylinder ford. I got the siezed stems out of the guides by turning the head upsidedown and leaving diesel soaking in the ports for a week or more. Some tapped out easily but others were stuck fast. I removed them with two hammers. I held one lump hammer squarely on the stem end to deaden the blow and preven tdamage and then hit the back of it with a second hammer. They slowly worked their way out.
Listermaniac is offline   Reply With Quote
Old 27-01-12, 11:05 AM   #4
NEVER, EVER, hit two hammer heads together!
The high velocity splinters from a shattered hammer head could kill you.
Protect the valve stem with something softer than the valve; a piece of alloy or brass would be ideal.
Old 27-01-12, 11:23 AM   #5
philip ashwin
i managed to free the valves on my wolseley by using WD40 and tapping it down with a brass screw driver and hammer my one were not stuck to bad
regards
philip
1946 Lister D, 2HP Lister D, Lister 2L, Wolseley WD2, Ecllispe Root cutter, HEC air compressor, Jap 2a shearing set, Pegson & marlow pump. Goodel & Pratt buffing/grinding wheel.
philip ashwin is offline   Reply With Quote
Old 27-01-12, 06:03 PM   #6
zakyboi
zakyboi's Avatar
mine arent too bad so a bit of wd40 and gentle tapping ought get the job done
Old 27-01-12, 06:30 PM   #7
If they are stuck fast Zak I would be inclined, on a D type, to refit the valve spring retainers into their slots as hitting on the valve stem just might distort the stem at that point, it will be the weakest part. Just a thought, that's all.
Windrush is online now   Reply With Quote
Old 27-01-12, 06:36 PM   #8
biggusdannus
biggusdannus's Avatar
Modern hammers won't shatter if hit with another hammer. You might get a very small chip off the edge but nothing that could kill you!! It is considered very bad practice to hit a hammer with another hammer but is most definately NOT life threatening! Dan
Cheers Dan
biggusdannus is offline   Reply With Quote
Old 27-01-12, 06:42 PM   #9
Ah... You must be better informed than me - I had no idea our friend was using modern hammers! When does "modern" start?
On the whole, better to be safe then very sorry!
Old 27-01-12, 07:03 PM   #10
Rookesy
The Wasp's revenge?
Mick
Rookesy is offline   Reply With Quote
