Old 26-03-16, 11:23 AM   #61
Originally Posted by David View Post
Any one know where I can get a hand cleaner called "Lava" Made by WD40.
David.
It's not cheap, good stuff though.
http://www.amazon.co.uk/WD-40-10086-.../dp/B0045LSUT8
Cheers, Steve
Old 26-03-16, 12:50 PM   #62
David
Cheers, Steve
Thanks Steve,
Never gave Amazon a thought, and yes it is good stuff.
David.
David is offline   Reply With Quote
Old 26-03-16, 01:00 PM   #63
Originally Posted by electrocutas View Post
Best stuff I used when I was in the plastic industry and Can I hell as like remember the name but it was just like the almond mix that goes into almond tarts Looks like it and smells like it with small beads in.
It worked a treat and really looked after the hands never dried them out.
Must try find the name..
I have some barrier cream (that I usually forget to use) which smells just like that - think this is the stuff http://www.pr88.com/products/products_pages/pr88.htm
Old 26-03-16, 10:26 PM   #64
userw7279
I use the froth off a pint of John Smiths, it doesn't work..... but!
userw7279 is offline   Reply With Quote
Old 26-03-16, 11:54 PM   #65
winchestergoose
I knew someone who used ''Gumption'' terrible stuff ,leaves your hands dry. He also used that stuff that the dry cleaners use carbon teterachloride .....I think he is no longer around!
I like goanna oil but you have to catch one first.
winchestergoose is offline   Reply With Quote
Old 27-03-16, 02:54 PM   #66
Combustor
Combustor's Avatar
Default Hand Cleaner (Cheap).
Forget all the big name industrial hand cleaners. Sure they work but I found that with continuous use my skin dried to the point of cracking and bleeding.
Go to your local supermart and buy a pump bottle of hand wash. Some will claim to be anti-bacterial but it's all the same. Wet your hands, put a shot on them, rub around and rinse. Reasonably kind to skin, quite cheap, and just buy the cheap re-fill packs for your pump bottle.
I use it for shower and shampoo as well and works as well as any expensive brew and I can't tell the difference. Regards,
Combustor.
Old 27-03-16, 10:15 PM   #67
Scott
Combustor.
Hello all
I must be tighter then you Combustor. I use the 'el-cheapo' dish washing liquid from Aldi and it's brilliant at taking the muck off your hands.
I do have the 20l sized drum of that pink coloured industrial cleaner in the shed but I reckon the dishwashing liquid does just a good a job, if not better. I'm thinking seriously of sending the industrial cleaner to the weekly auction we have here simply to free up some shed space.
https://youtu.be/CXvUXM3xURU
Cheers Scott
