Old 22-08-11, 05:53 PM   #21
steamboy1986
steamboy1986's Avatar
i have found the latex glove trick works very well , and using atrixo after does help .
but if not wearing gloves and you have removed all that you can do with the cleaner and there is still grime left , Lynx shower gel and a nail brush does work a treat .
but i have got these gloves which work a treat for protecting your hands if you dont like latex gloves .
thanks
Aaron
villiers mk12 with beresford water pump , wolseley wd 8 with a climax FH water pump , Villiers with Allam MiniGen dual output Generator , Villiers F15 Tarpen 110V Gen set
steamboy1986 is offline   Reply With Quote
Old 22-08-11, 09:20 PM   #22
AdeV
I use vinyl gloves (cheaper than latex) all the time when I'm mechanicing or machining; so long as you keep an eye on them & replace when they inevitably split, your hands stay bone dry & clean as a whistle...
For the times when I'm too lazy/forget/don't notice a split glove, I use the "Tufanega" Orange (aka orange swarfega with bits in) out of a wall dispenser, which works pretty well, but not quite as well as the (same) stuff you scoop out of a tub.
AdeV is offline   Reply With Quote
Old 22-08-11, 09:47 PM   #23
Mrsteamdan
Mrsteamdan's Avatar
I only use the old fairy green block soap thats not bad at removing grime
Bamford EV1 1935--Petter W1Vo1951 -Ruston & Hornsby 6pb 1932-Lister D 1939-110v dynamo Villiers Mk 2 1950s - Atco Standard 1929 -Atco Deluxe 1935-98cc suffolk-Climax water pump-Marco Comprrssor
Mrsteamdan is offline   Reply With Quote
Old 24-08-11, 08:02 AM   #24
listerlad
listerlad's Avatar
We use Swafeger wipes at work. There very good and shifting grime off hands. Mind you, were suppose to wear gloves if I rember to put them on which I userly do. Make your hands stink of laytex though.
Ollie
Lister D, Lister A, Lister CS 3-1, Bamford EG3, Ruston & Hornsby 6PB, Ruston & Hornsby 8PB, Ruston & Hornsby PT, Fairbanks Morse Z, Stuart Turner P4, Alco Featherweight.
Old 16-10-11, 04:51 PM   #25
gardnerman
gardnerman's Avatar
I've been looking at this for a while and I have tried lots including Swarfega, Tufanega, fairy liquid with vim (yes my hands get evil and need something that scrapes).
I found in my clear out a container of something cal;led Solopol, it has powdered walnut shell and citric acid amongst other things and it's brilliant, I googled it and it's readily available even from my local Cromwell tool supplier.
Richard
Don't ever give up
Old 16-10-11, 10:03 PM   #26
Listermaniac
Banned
Originally Posted by wolseley phill View Post
And another one...white spirit works well for really grubby hands, but probably not that good for you....
Yes, the rubber gloves do work really well, I have noticed this a few times.
At a SafePass course i was on in January, we were told that it soak through the skin and poisons the bloodstream and can make you all drowsey and kock you out when it gets to your brain. I'd say you'd have to have a bath in it for that to happen.
Once in a while is OK I guess, but not on a daily basis.
"i feel dowsey. I must have some blood in my white-spirit stream"
Anyway, when i get really greasy I find plain old washing powder unbeatable. The gritiness really helps too. None of your fancy plant oils or eco-granules for me thank you very much!!
Listermaniac is offline   Reply With Quote
Old 16-10-11, 10:33 PM   #27
gardnerman
gardnerman's Avatar
May be just me but when I use washing powder I need to wash again with soap as it leaves my skin sticky no matter how much I rinse.
Richard
Don't ever give up
Old 16-10-11, 11:08 PM   #28
Listermaniac
Banned
yeah, i find it stays "slippery" for a lot longer than normal soap when rinsing. I find myself using an extended rinsing period.
Old 16-10-11, 11:23 PM   #29
The wild eye
The wild eye's Avatar
You big bunch of fairies .
Just rub yer hands on your jeans .
Steve
Old 16-10-11, 11:27 PM   #30
Listermaniac
Banned
Steve
Fairies. yeah.
Chuck Norris washes his hands with concentrated acid, and cleans the dirt from under his nails with a chainsaw. So come on, man up lads!
