Old 21-08-11, 09:37 PM   #1
Default Clean hands
Gentlemen,
My day job means I have to wear latex/rubber gloves, I dont like to but I have found that if you have had a busy oily weekend and soap has'nt shifted the ground in dirt put on a pair of these gloves for an hour or so and I guarantee your hands will sweat out the grime. No need for chemical or gritty cleaners.
Old 21-08-11, 09:40 PM   #2
Oo might try that, fed up using a mix of swarfega and vanish powder!
Ta Very Much
Cheers Steve
Old 21-08-11, 09:44 PM   #3
We use Suprega, fruit oils and nylon granules, much better than Swarfega.
The new containers are called "Swarfega Natural Orange".
Old 21-08-11, 09:47 PM   #4
matt86
matt86's Avatar
fairy liquid and sugar works well , doesn't dry your hands out either
matt86 is offline   Reply With Quote
Old 21-08-11, 09:48 PM   #5
Suffolkcharlie
Suffolkcharlie's Avatar
Thats what i use, much better than the normal swarfega, and a few months back they were 6 pound in homebase for a 4 liter tub with a pump so i brought 4! there alot more now!
1934 Lister DK shafty Lister LR1 genny Suffolk & Atcos Wolseley WD8 Stuart T pump Drummond 4" lathe
"Proper engines don't have spark plugs!"
Suffolkcharlie is offline   Reply With Quote
Old 21-08-11, 09:48 PM   #6
I found that fairly liquid makes my hands dryer.
Cheers Steve
Old 21-08-11, 09:55 PM   #7
mo3mini
mo3mini's Avatar
I use Swarfega. Not the modern stuff, we have bottles of old stuff :)
Old 21-08-11, 09:58 PM   #8
Suffolkcharlie
I Also forgot to ad that i rub a small amount of atrixo in to my hands to put the mosture back in at the end of the day if i have been working on engines
Old 21-08-11, 10:10 PM   #9
janner
being in the chemical job has entitled me to try a few things, most succesfully with ground in dirt is to use TFR neat, works a treat but be sure to moisturise straight away as it removes the skins natural oils too, jon
Old 21-08-11, 10:28 PM   #10
mtinelle
We use ford motorcraft hand cleaner -dont know the part no if anyone wants it pm me - seems to do a better job than any commercial brand & its about 12.00 for 10 litres , the main ingredient is wood pulp !!
Martin
mtinelle is offline   Reply With Quote
